89' Corolla on 17" Lexani's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2010, 11:58 AM   #1 (permalink)
View super89corolla's Photo Gallery
Gen6 89' Corolla on 17" Lexani's
Hello,
Im in the need of some assistance I have a 1989 corolla and I just got some 17 inch lexani rims with tires for it. I put the front two on with spacers and it had enough room to turn and everything it went on perfect. Then I put the back two tires on with spacers. The right side/passenger side went on fine it fit perfectly but then the drivers side/left side of the car the rim would do a rotation and hit the strut every time. So then I thought maby the rim was bent so I switched the two rear sides and I had the same problem so it isnt my rims. It wasnt a constant grinding it was more of the rim would hit only at a certain time every rotation. What could be wrong with my corolla that would make just that one side hit like that ?
super89corolla is offline   Reply With Quote
Old 03-13-2010, 01:28 PM   #2 (permalink)
Blof-fan's Avatar
Gameroom cash: $294850
View Blof-fan's Photo Gallery
Maybe the hub itself is bent a little or something like that.
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is offline   Reply With Quote
Old 03-13-2010, 03:59 PM   #3 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Try cleaning the mating surface of the hub with a wire brush to see if that helps.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
