Timin Belt Kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2010, 06:03 PM   #1 (permalink)
View phatride4ever's Photo Gallery
Timin Belt Kit
I still have my original Timing Belt so I am replacing it next week. So far I am going to get a Timing Belt component set (belt/tensioner). New waterpump and gasket. A new engine mount by the radiator. 1991 4AFE
-Is there any special tools I need, like to remove the crank pully?
-Any kits that you recommenced/dont recommend? I am trying to buy bulk from RockAuto.com
phatride4ever is offline   Reply With Quote
Old 03-23-2010, 06:21 PM   #2 (permalink)
Gameroom cash: $816901
View zythr's Photo Gallery
Yes you need special tools. You'll probably need an engine lift or something that will raise the engine enough so that you can have better access to the covers. Might as well get your seals, (oil, crankshaft, camshaft) since you'll be replacing the belt.
zythr is offline   Reply With Quote
Old 03-23-2010, 06:26 PM   #3 (permalink)
Well I can just put the engine on a jack with some wood. I was talking more about specialized tools like for my 3.7L Tacoma I needed to buy a special tensioner pusher to push the tensioner back during re-installation of the belt.
Old 03-23-2010, 06:37 PM   #4 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
I did that same job recentally I got lucky my crank pully came off with my bare hands.. Be sure to get cam seal, crank seal, and a new o ring for the dipstick tube.. I also did the thermostat on the other end of the engine where the lower radiator hose connects to the engine..When you get down to the water pump you will notice the water pump is a 2 piece, My water pump basically exploded and gouged the small plate that the water pump is mounted to forcing me to buy a Toyota water pump because they sell both pices as an assembally..Good luck
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline   Reply With Quote
