rattling noise under load - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2010, 11:53 AM   #1 (permalink)
View alfaffa's Photo Gallery
Hi!
I am the owner of a corolla ae92 with the 4a-f engine.
over the past few weeks the car has started to make a rattling noise when the car is under load.. It sounds like something has become loose inside the engine, like i bolt or a nut or something like that.. The rattling raises with the rpm. If i try to raise the rpm with the car out of gear the rattling is pretty much imposible to hear.
The rattling gets worse when the engine gets warmed up
Has anyone had the same problem or might know what it could be?
Sorry for my bad english, im from denmark.
alfaffa is offline   Reply With Quote
Old 03-24-2010, 02:01 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Most of the rattles I've seen like this deal with the exhaust. Either from a heat shield or a rusted out section. My corolla had so many exhaust issues so I'd get an odd rattle in the exhaust every 3 months. My celica has one as well, I've just yet to trace it down.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 03-24-2010, 03:09 PM   #3 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Description sounds like pinging. Check to be sure timing is set to spec. If you have a vac advance on distributor make sure vac lines don't have a leak. Can also try going up one grade in gasoline over the 87 octane. As engine gets more mileage carbon buidup can also be a factor.
90 GP is offline   Reply With Quote
