1991 Toyota Corolla DX BRAKE and BATTERY light on at same time. - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2010, 09:41 PM   #16 (permalink)
View hastings900's Photo Gallery
Brake light and battery light
Hey guys just remember that if you pull the alt out and have it tested and it test good then look at the post that comes off thesside of the alt it is possible that the connector on the end of the wire might be bad
have a great day!
Gary
hastings900 is offline   Reply With Quote
Old 02-17-2013, 06:33 PM   #17 (permalink)
View 3joet3's Photo Gallery
Would this be the same case with an 1989 22r pick up?
3joet3 is offline   Reply With Quote
Old 02-17-2013, 07:49 PM   #18 (permalink)
Senior TN Member
Donald's Avatar
Gameroom cash: $208020
View Donald's Photo Gallery
I would say yes.
Charge and brake light on together usually means your alternator is dead.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'97 T-100, V6
Donald is offline   Reply With Quote
Old 02-18-2013, 11:59 PM   #19 (permalink)
View tashirosgt's Photo Gallery
On cars as old as the 6th gen, its important to check for broken wires. I had a "bad" alternator that tested good. The problem was that one of the 3 wires in the 3 wire connector to the alternator was broken very near the connector. I had to look very closely to see this. The break was so close to the connector that I had to cut off the whole connector and solder on a connector from a junk harness that I had.
tashirosgt is offline   Reply With Quote
Old 02-19-2013, 03:50 PM   #20 (permalink)
Senior TN Member
Donald's Avatar
Very good point!!
'97 T-100, V6
