Originally Posted by kwint
There are 2" drop springs for the 93-97 models. The fronts will fit your stock shocks, and the rear would need the top hat from a 93-97 model.
None of the drop springs have an even drop. The corolla has a rake to it from the factory and lowering it amplifies this.
I had some '93 Corolla lowering springs sent to me in error, and they wouldn't fit the lower spring seat on the front struts of '92 Corolla. They were just a bit too wide and sat part way up on the lip of the seat, for about 1/3 of the circumference.
I have used fully adjustable coil-overs on my car, and I wouldn't reccommend more than 1.5" drop unless you are using very stiff
racing springs, as carrying passengers will be impossible, and speed bumps will require a diagonal approach.
The Eibach lowering springs that I have on now give a 1.3" front and 1.5" rear drop, I think.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
