Transmission woes :o( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2010, 07:36 PM   #1 (permalink)
View Valkyrie90AE92's Photo Gallery
AE92 Transmission woes :o(
Hi
Had a previous thread about the clutch being nosiy, but now I have a whole new set of problems. Left the car sitting for a couple of days, then when I started it, it wouldn't move. Clutch was going to the bottom, but not really doing anything. Since the clutch was so limp, I replaced the slave and master clutch cylinder. Got the car put back together (btw, that master cylinder is a royal pain in the butt, but that is a rant for another day). Bled the lines, and once the car starts...... I can't shift into any of the forward gears. At all. Only gear that I can shift into is reverse, and once I shift into it, the car starts moving, even if the clutch is pushed in all the way. As far as the forward gears, if I push the shifter in (as far as it will go), the car will very slowly move forward. If the car is turned off, I can shift into any gear without the clutch.
Anyone have any idea what I need to look for? I mean, I thought I might need to do a better job bleeding the lines, but I doubt a little air would have this weird effect. I'd hate to take it to the shop, but this might be my only option. Hopefully I can get some ideas here.
Thanks!!
--1990 Toyota Corolla AE92
--234K miles
--5 Speed
--KYB GR2 shocks/Eibach springs
Valkyrie90AE92 is offline   Reply With Quote
Old 04-01-2010, 02:44 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
It could be your clutch friction plate and/or pressure plate. But before those, check the cables for any looseness.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 04-01-2010, 10:52 AM   #3 (permalink)
Blof-fan's Avatar
Gameroom cash: $294850
View Blof-fan's Photo Gallery
Bleed your lines a little better and double check the line connections. Your clutch just isn't working.
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
Old 04-01-2010, 12:50 PM   #4 (permalink)
View Murgatroy's Photo Gallery
I have to agree with this.
Murgatroy is offline   Reply With Quote
