Hood scoop properties - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2010, 03:58 PM   #1 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Ok, so hopefully I get a hood scoop. I won't be running a s/c but I want the hood scoop for looks and primarily for cooling of the engine bay. My hood gets hot! Not like my engine is overheating or anything, but it gets hot.
The only thing, water issues like driving in rain and rain getting into the engine bay (more water than the usual splash from the ground). I'm sure there shouldn't be any problems. But if there is, what would it be?
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 04-02-2010, 08:45 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
usually with a 4AGE you have the problem of getting water in the spark plug valley... 4AFEs I don't think you would have that problem, but who knows.
Old 04-02-2010, 11:12 PM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Yea, some thing like that I'm worried about.
I'll be dropping in a 4age ST in the future. It does have a plug cover, I think the plug boots have like a cover that closes the plug holes... But water can seep into anything.
Old 04-02-2010, 11:27 PM   #4 (permalink)
View Murgatroy's Photo Gallery
I have a scoop on my Celica. Had it on there for a couple of years. I have never had an issue with water in the engine bay. That is not to say I haven't had water in there, but the water hasn't created any issues.
Murgatroy is offline   Reply With Quote
Old 04-03-2010, 07:21 AM   #5 (permalink)
View bcp477's Photo Gallery
Water in your distributor....that is the main worry with a hood scoop. As for cooling, a scoop won't do much in that regard... but you said you wanted it for looks , anyway.
bcp477 is offline   Reply With Quote
Old 04-03-2010, 09:00 AM   #6 (permalink)
Frozentide's Avatar
View Frozentide's Photo Gallery
Well a hood scoop will help with cooling, and if he does swap in a ST eventually and puts velocity stacks onto the ITBs, then the hood scoop will GREATLY help the engine's cooling.
CURRENT: 1990 Toyota Corolla SR5, 273,xxx kms - Track Car
History:
1994 Toyota Corolla Special Edition - RIP Old Age @ 454,986kms
1986.5 Toyota Supra NA mint condition - RIP Totalled during Police chase @ 115,112kms
2000 Toyota Corolla CE - Given to parents, since Insurance = $1000/mth approx
Frozentide is offline   Reply With Quote
Old 04-03-2010, 11:23 PM   #7 (permalink)
SCT
iAzn
SCT's Avatar
I don't think I'll be running ITB stacks since I'm going for a turbo set-up.
I figured the hoodscoop would allow heat to flow out through the hood rather than try to seep out elsewhere like usual. And driving, self-explanatory.
Old 04-04-2010, 08:54 AM   #8 (permalink)
Ok, so intake of air for additional cooling (or for engine aspiration) isn't the point.... EXHAUST of heated air from the engine bay is. In that case, you'd be better off reversing the scoop... with the opening to the rear....to take advantage of the low pressure area at the base of the windshield, and help pull air through the engine bay. That WOULD improve cooling. Placing the scoop so that fresh air will be rammed into it.....when you really want the opposite effect.....won't do much, as I said before.
Old 04-04-2010, 09:27 AM   #9 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
You would get better engine bay cooling if you do the scoop and have some louvers at the back of the hood or out the fender sides.
RED91SR5 is offline   Reply With Quote
Old 04-04-2010, 05:42 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Louvres on the sides of the fenders wouldnt do shit, as theres no airflow from the engine bay to the sides of the front fender. WRX style scoop would only increase drag and unnecessary air flow to the engine bay, evolution style scoop would be the only one that would work in your case.
But why do you need it, just because your hood is getting hot doesnt mean shit, my hood gets so hot that it warps a bit when it gets to full temp and you cant lay our hand on it till it cools down, because the turbocharger is sitting few cm under it. You could literally boil eggs on it.
Theres no low pressure area at the base of the windshield, whatever it would be relatively high pressure there and thats where the air to the cabin gets in (if it would be low pressure, it would suck air out from the cabin). I dont know about you, but I dont really want heated air coming in while I'm driving.
Old 04-04-2010, 07:49 PM   #11 (permalink)
SCT
iAzn
SCT's Avatar
AE92
Didn't say I need it, I want it... My hood is somewhat warped from heat, too, where the ridges are. Just questioning any possible issues. I'm not turning the hoodscoop towards the rear, I might just well take a hammer and bash the center back of the hood to form a cowl (cowl hood) but I'm not doing that. I think the opening of the scoop is enough to let the heated air escape, I don't need for it to force it out.
Old 04-04-2010, 09:13 PM   #12 (permalink)
RED91SR5's Avatar
Originally Posted by Flashmn View Post
Louvres on the sides of the fenders wouldnt do shit, as theres no airflow from the engine bay to the sides of the front fender. .
That's why you install ducts to the fender louvers, there isn't any cars other than old model A hot rods that have direct openings to the fenders.
Old 04-05-2010, 03:39 AM   #13 (permalink)
Resident asshole
Flashmn's Avatar
Yeah and while you cut out the metal to put the ducting, you're weakening the chassis aswell at the same time.
Old 04-05-2010, 01:43 PM   #14 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
cowl hoods don't suck air out, they force air in.
There is a high pressure area in front of the wind shield and it forces into the area above the engine where in most cars that had a cowl hood is where the air filter sits.
'81 BMW R65
Old 04-05-2010, 11:04 PM   #15 (permalink)
RED91SR5's Avatar
I'd say it would have to be a pretty big hole to weaken the chassis, and if done right you actually add to the chassis strength, i.e metal vent channels to the louvers. They don't have to be that big to vent the engine bay either. We do it in dirt track racing cars all the time around here because scoops just shove the mud in the engine bay. Now these cars get hot under the hoods but were talking V8 muscle.
