Oil leaking. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2010, 01:19 PM   #1 (permalink)
Tuso4l
View tuso4l's Photo Gallery
Oil leaking.
I have this oil leak and it leaks a lot! I finally found the part thats leaking and despite working on cars i have no clue what the hell it is anybody know?
If the shoe fits throw it over a wire.
tuso4l is offline   Reply With Quote
Old 04-03-2010, 02:14 PM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
What you circled is the mechanical fuel pump since you have a carburetor. If it is leaking oil you might need the gasket( if you can buy it separately) that goes between the pump and the engine.
90 GP is offline   Reply With Quote
Old 04-03-2010, 02:22 PM   #3 (permalink)
Tuso4l
Ill check into that thank you
Old 04-04-2010, 04:51 PM   #4 (permalink)
Tuso4l
any body know if it is an o ring or a gasket?
Old 04-04-2010, 05:40 PM   #5 (permalink)
If I remember it is a thick gasket that goes between fuel pump and side of engine. If it can be replaced separate from pump it would likely be only thru Toy dealer. Might want to price a new pump and see if it comes with the gasket. Have you tried tightening the two bolts that hold pump in place? They might simply be loose allowing the oil to seep out. Are you sure it's leaking at pump? A more likely spot is the valve cover gasket directly above it or the distributor O ring .
Old 04-04-2010, 06:02 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Theres two gaskets on each side of the thick plastic spacer. You can use engine sealant on it (hylomar or permatex gray for example). But are you sure its oil not fuel, theres a weep hole on the lower part of the pump and it leaks out fuel when the fuel pump wears out.
Old 04-04-2010, 06:54 PM   #7 (permalink)
Tuso4l
@90gp and @flashmn
I am 100 percent sure.it leaks from the middle of the casing all over the tranny. I thought it was the valve covers but apparentlly not. i was trying to jump my tractor and watched it seep some out. im also 100 on it being oil i still have a stain on my Drive from december
Old 04-07-2010, 10:18 AM   #8 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
yeah it's just gaskets, easy fix. When I read oil leak threads I always worry when opening them thinking I might see pictures that show a blown headgasket lol.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
