So I was working on my rear disc brake swap last night, and I went to swap the brake line from the drum brake line to my new stainless steel GT-S brake line (goodridge) and for some reason the hard line on the body will not screw into it...
does anyone know if it's a different size on GT-Ss? I sat there for like 15 minutes trying to screw it in and it wouldn't go in, and then I screwed it into the rubber drum line again no problem...
so my question is, is it a faulty brake line? or are they supposed to be different sizes? I'm guessing the brake line...
'81 BMW R65 For Sale: GT-S strut bar + Front GT-S koni yellows
I've swapped three sedan's and one sr5 to disc and never had an issue with them. On my current sedan I'm using the Russell kit for ae86/ae92 with no problems. Check the first threads of each end mayby they rounded off a bit.
WTB: Rear TRD sway bar for ae92
Do they not fit at all or do they start to tighten like for ½ turn and then get stuck? Could be a bad batch if thats the case. Corollas use IIRC TX-fitting threads on the brake lines.
I just tried again. they don't tighten at all, it just spins, but it looks like it's the same size if I look at both of them.
after I tried for another like 5 minutes I screwed it back into the stock lines pretty easily again....
is anyone running goodridge lines?
