When you get a change check your plugs, make sure they are not black, if they are it means that you are running very rich. Also when this happened to me it was because my valves were very dirty and they were not sealing right so fuel escaped unburned and it would cause the car to smoke. Start cheap, put some car cleaner in the carb and some fuel Lucas fuel treatment and if push comes to shove treated it with Seafoam. You might be able to clean it up without taking it to a mechanic. The car might have been mistreated b4 you got it.
