1989 corrolla all trac no fire. please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2010, 08:00 PM   #1 (permalink)
View hauntedz28's Photo Gallery
Ive read a few posts and got no real answer. Installed brand new distributor and I still have no fire. new cap and rotor. dont have a book where else can i look for no fire? what wire is 12v to dist? 205lbs each cylinder on compression check, so belt is good. 1.6 motor. thanks
hauntedz28 is offline   Reply With Quote
Old 04-11-2010, 08:24 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
ignitor? Can't remember if the 4AFE's have one... if they do check it.
Is your fuel pump supplying fuel, could be a dead pump as well.
Old 04-11-2010, 10:04 PM   #3 (permalink)
It has no spark. Isnt the ignitor and the pickup coil the same thing? Everything in the distributor is new. I think it could be the ecm. Shouldnt the check engine light come on for a brief second when the key is turned over? cause mine dont.
Old 05-15-2010, 01:58 PM   #4 (permalink)
View bestdada's Photo Gallery
There is a fuse the power goes through the check engine light to the ecm if that fuse is no good the engine light will not come on and the ecm will be missing a power supply it is a 7.5amp fuse under the driver left foot in fuse block give that a try
bestdada is offline   Reply With Quote
Old 05-15-2010, 04:00 PM   #5 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
The ignitor/ coil pack is built in with the distributor.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 05-15-2010, 07:13 PM   #6 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Did you verify whether bulb for check engine light in cluster is burnt out? Might be a long shot but if that bulb completes a circuit for powering up ECU it could be the culprit.
90 GP is offline   Reply With Quote
Old 05-15-2010, 07:32 PM   #7 (permalink)
Yes I checked there is a 7.5 amp fuse by the driver foot kick panel it is good and the engine light bulb dose come on.
