computer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2010, 08:29 AM   #1 (permalink)
View eishiba's Photo Gallery
computer
Silly question but does a 91 corolla have a computer you can read codes off of? Or is this specific car too old? If it does where is the location and how do you do it?
eishiba is offline   Reply With Quote
Old 04-14-2010, 08:46 AM   #2 (permalink)
heartdisease's Avatar
Gameroom cash: $114370
View heartdisease's Photo Gallery
I would think that would be obdI
You can go to autozone and they will give you a fancy paperclip and a book. You poke the wire into the obd port and count the blinks.
heartdisease is online now   Reply With Quote
Old 04-14-2010, 10:50 AM   #3 (permalink)
Does it need to be for a toyota or is it just a universal scanner. Where do you hook it up at? All autozone gives is a paperclip and a book? Whats the book for? The paperclip sounds retarded.
Old 04-14-2010, 12:37 PM   #4 (permalink)
On board diagnostic one. Usually the port is by your left knee just under the edge of the dash, drivers side. You put the clip across two of the contacts and then the check engine light blinks a certine number of times. The book tells you what the code is.
Old 04-14-2010, 05:07 PM   #5 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Link on how to jumper two connections at diagnostic port and read the codes from number of blinks:
http://www.troublecodes.net/Toyota/
90 GP is offline   Reply With Quote
Old 04-14-2010, 05:29 PM   #6 (permalink)
Frozentide's Avatar
View Frozentide's Photo Gallery
The reason you have to use the paperclip method is because any car before 1996 is OBD1 and EVERY car manufacturer uses different shaped ports and different computer technology. From 1996 on every car uses a standard OBD2 port and computer technology so a standard scanner can be used.
You can go buy an OBD1 scanner and the specific Toyota adapter, but why spend a few hundred bucks when a paperclip and blinking light will give you just as much info. (OBD1 scanners only tell you the number anyways)
This is why for the DIYer OBD1 is easier and cheaper. You can find the OBD1 Toyota codes only too if you search.
CURRENT: 1990 Toyota Corolla SR5, 273,xxx kms - Track Car
History:
1994 Toyota Corolla Special Edition - RIP Old Age @ 454,986kms
1986.5 Toyota Supra NA mint condition - RIP Totalled during Police chase @ 115,112kms
2000 Toyota Corolla CE - Given to parents, since Insurance = $1000/mth approx
Frozentide is offline   Reply With Quote
Old 04-14-2010, 08:31 PM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
you gotta jump the ports in the engine compartment on a coupe... sedans I'm not sure if the port is in the same spot.
Old 04-14-2010, 10:55 PM   #8 (permalink)
Custom User Title
65Pontiac's Avatar
View 65Pontiac's Photo Gallery
yea its the same spot, by the fuse box and strut tower, its a gray little cover that says diagnostics
1992 Corolla DX 87k miles, stock
1965 Pontiac Tempest Custom, 326ci H.O, cam, headers, edelbrock intake/carb, hpipe, dynomax race bullets, side exit exhaust, M22 "rock crusher"
65Pontiac is offline   Reply With Quote
