how to hit 8000rpm? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2010, 09:05 PM   #1 (permalink)
Regular TN User
View rudy_kid's Photo Gallery
how to hit 8000rpm?
any suggestions?
how about 9000rpm?
i have a 90 gts
im getting my engine rebuilt right now
so yeah ill have a GOOD base
rudy_kid is offline   Reply With Quote
Old 04-27-2010, 09:28 PM   #2 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Drop it from 4th into 2nd at redline? What are you asking here and what do you mean by rebuilt?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 04-27-2010, 10:25 PM   #3 (permalink)
View big_daddy234's Photo Gallery
more lift and duration on the cam , get your head ported and bump the compression up , ask your machinest for more details.
big_daddy234 is offline   Reply With Quote
Old 04-27-2010, 11:09 PM   #4 (permalink)
BackYard Engineering
Evo_lucian's Avatar
Gameroom cash: $102535
View Evo_lucian's Photo Gallery
why do you wanna hit 9000 rpm ?
The only thing in life worse than being talked about is not being talked about
My website updated 6/May/11
http://budgetracer.webs.com/
Evo_lucian is offline   Reply With Quote
Old 04-27-2010, 11:19 PM   #5 (permalink)
Regular TN User
i should have worded it better
i meant to say is more like how can i increase my rev limit to 8krpm
the 9k was just curiosity but im serious about hitting 8k
would it be very difficult?
i heard that a lightweight pulleys and flywheel can help
Old 04-27-2010, 11:35 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996375
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
If you want to rev above redline, you will need to upgrade your valve train with stiffer valve springs to avoid valve float. Lighter lifters would help too.
The Jedi Speeder at CarDomain
Old 04-27-2010, 11:38 PM   #7 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
you need a way of raising your limiter to 8000 rpm if you want that
you need fuel and spark control + valve springs for 9000rpm
but for more power and longevity at 9000rpm range you need other modifications
canadianae92 is offline   Reply With Quote
Old 04-28-2010, 04:46 AM   #8 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
... why the want to hit 8k/9k+ RPM?
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 04-28-2010, 06:56 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
And stiffer valve springs will cause other problems, like the wear of cam lobes for one, If you want to rev to 8k, get a motorcycle.
Old 04-28-2010, 08:55 AM   #10 (permalink)
Frozentide's Avatar
View Frozentide's Photo Gallery
I'm with most of the ppl who have responded: WHY DO YOU WANT TO REV YOUR RPM'S THAT HIGH??
It won't make more power.... if you think that you haven't seen a dyno chart, and don't know what a torque curve is. Also horsepower as a measurement really doesnt mean much at all. Torque is all that matters, horsepower is just a way of showing torque multiplied by time.
MEANING: If you have 2 identical engines in 2 identical cars:
Engine A: max power is rated at 120hp @ 7000rpm and 100ftlbs @ 5000 rpm
Engine B: max power is rated at 150hp @ 8500rpm and 100ftlbs @ 5000 rpm
Which is more powerful and therefore faster?
Answer: THEY ARE THE SAME!!! The only difference is that if you ride the rpms to the limit you can shift later and might gain an advantage because when you shift, you will be at a higher rpm for next gear, however if your torque curve drops significantly between 6500-8000rpm then you are no longer taking advantage of the accelleration (which is usually the case).
There is a reason that people install shift lights, because you want to have them flash when you have reached the optimum power vs rpm spot to shift.
I hope this helps...
CURRENT: 1990 Toyota Corolla SR5, 273,xxx kms - Track Car
History:
1994 Toyota Corolla Special Edition - RIP Old Age @ 454,986kms
1986.5 Toyota Supra NA mint condition - RIP Totalled during Police chase @ 115,112kms
2000 Toyota Corolla CE - Given to parents, since Insurance = $1000/mth approx
Frozentide is offline   Reply With Quote
The Following User Says Thank You to Frozentide For This Useful Post:
rudy_kid (04-28-2010)
Old 04-28-2010, 10:39 AM   #11 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
Rev too high make engine go boom
Createdtoburn is offline   Reply With Quote
Old 04-28-2010, 10:41 AM   #12 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
You could swap in a Blacktop 20V
also, look at this site: http://www.billzilla.org/4agmods.htm
My Corolla and my RX-7 rev higher than my motorcycle does lol
'81 BMW R65
Old 04-28-2010, 02:54 PM   #13 (permalink)
Gameroom cash: $134355
stock 4age can easily handle 8500, actually so an 8k rev limit isn't all that high.
the better question is if you're getting a stock rebuild and stock cams, why would you want to go higher? Your power band will fall off drastically before you hit 8,000 rpm's (I have mine set at 7800 and I can feel it fall out of breath) due to limitations of the stock cam.
If you came in and said you were upgrading your valvetrain then I might tell you how to actually change the stock ecu's rev limit. Not many know how to do it -- including most "tuning" shops.
Old 04-28-2010, 03:19 PM   #14 (permalink)
SuLLiVaN88's Avatar
Gameroom cash: $122837
View SuLLiVaN88's Photo Gallery
hell if you want to rev so high why not put in a rotary motor! but other than that these cars have a dam impressive rev limit stock
SuLLiVaN88 is offline   Reply With Quote
Old 04-28-2010, 03:19 PM   #15 (permalink)
j2b4osan's Avatar
View j2b4osan's Photo Gallery
Buy a civic with a b16......
88 sr5 100k Stock.
j2b4osan is offline   Reply With Quote
