cluster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2010, 09:30 PM   #1 (permalink)
View Angel13's Photo Gallery
AE92 cluster
Any body now where i can find a DIY for the gauge cluster to chage the lights to different color.
Angel13 is offline   Reply With Quote
Old 04-27-2010, 09:34 PM   #2 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
No, but it should be simple. They will be type 194 bulbs and easily swappable once you get the cluster out. I haven't removed it from my Corolla yet but in every other Toyota, the speedometer cable has been a hassle to get in and out.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 04-27-2010, 10:17 PM   #3 (permalink)
View 4dRcOrOlLA's Photo Gallery
yea its simple jus remove ur dash then the bolts, take ur cluster out, the secrete of the speedmeter cable is that u can actually push it from under the hood to give u more room to play wit then pull it back b gentle and good luck
4dRcOrOlLA is offline   Reply With Quote
Old 04-28-2010, 04:49 AM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Yea, the speedo has a small tab that's facing towards the passenger side. Locate it with your fingers, push it, and it'll pop off.... I have small hands :p
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 04-28-2010, 07:36 AM   #5 (permalink)
so i have to take the dash of?
Old 04-28-2010, 02:34 PM   #6 (permalink)
SCT
iAzn
SCT's Avatar
The center console trim that surrounds the cig lighter/ cup holder/ ac controls/ center vents, the black trim that surrounds the radio/ cluster, then you get access to the screws that holds the clusters.
Assuming you have a sedan, not sure if the 2 doors are the same way.
Old 04-28-2010, 04:01 PM   #7 (permalink)
i have a 2door
Old 04-28-2010, 04:08 PM   #8 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
Originally Posted by Angel13 View Post
i have a 2door
Yes the cluster has to come out. A 10 minute job though, if that. I find the coupe's clusters come out easier then the sedans and I've nver had to undo the speedo cable as it's fixed in place in the coupes. With the sedan's speedo I find it faster to take the radio out to be able to get your hand behind the cluster and undo the speedo and out it back on.
Anyway, as already said, once the cluster is out the bulbs are very easy to change out.
RED91SR5 is offline   Reply With Quote
Old 04-28-2010, 04:31 PM   #9 (permalink)
Where do i start thogh
Old 04-29-2010, 12:42 AM   #10 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
Oh jeeze. You probably shouldn't be trying if you have no clue at all how to do it. Ask a friend with some experience.
Createdtoburn is offline   Reply With Quote
Old 04-29-2010, 09:14 PM   #11 (permalink)
i could probably do it just havent really tried or checked but just thought there could of been a diy for this
Old 04-30-2010, 09:41 AM   #12 (permalink)
RogueMoog's Avatar
Gameroom cash: $313930
View RogueMoog's Photo Gallery
I never removed a gauge cluster from a car before, and had no problem removing my All-Trac's cluster. Of course I had pulled apart the front dash several times since I bought the car to get at the stereo & front speakers... it was just a matter of removing the right screws to get the cluster out. (I have issues with my speedometer needle bouncing like crazy when the weather is cold, or when I go about 65mph. So I checked the cluster and did the test on the speedo sensor as the FSM suggested.)
I suggest what someone else has already said, to make this easier, it might be better to detach the cable in the engine bay and feed some of it through the firewall so that the cluster is easier to pull back once it's been detached.
RogueMoog is offline   Reply With Quote
Old 04-30-2010, 06:14 PM   #13 (permalink)
jus give your self a whole day to experiment and never force anything!! and u should b ok
