Mk1 mr2 steering wheel to ae92 corolla? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2010, 02:01 AM   #1 (permalink)
Delacourt1's Avatar
View Delacourt1's Photo Gallery
Hi
I have a 1992 model ae92 rolla.
I wonder if mk1 Toyota MR2 steering wheel fit into my car without any adapters ? Or should I have to use a kind of adapters.
The MR2 steering wheel comes with its own boss.
Here is a picture of the steering wheel that I would like to fit into my rolla. Any ideas ?
Delacourt1 is offline   Reply With Quote
Old 04-30-2010, 02:38 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
FYI, the previous generation Corolla's came with the similar design steering wheel except without the MR2 logo. I think either should fit, but not sure.
You can also look up the steering wheels from the AE92 SR5/GTS 2 doors. Designs differ a bit from the MR2 picture you have there, but similar.
... or go aftermarket.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
The Following User Says Thank You to SCT For This Useful Post:
Delacourt1 (05-02-2010)
Old 04-30-2010, 10:43 AM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
http://www.momousa.com/products/prod...yota-hubs.html
it doesn't look like it. They have different hub part numbers for aftermarket wheels which means they're probably different.
A friend is actually going to give me one though that I was already planning on trying, so we'll see.
'81 BMW R65
The Following User Says Thank You to eage8 For This Useful Post:
Old 04-30-2010, 08:58 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
That's right, it said TOYOTA on it... I believe some AE92s had a similar one as well.
Old 05-01-2010, 02:57 PM   #5 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Originally Posted by Delacourt1 View Post
Hi
It should work fine. I have used the same aftermarket steering wheel and hub on my Corolla, MR2 (mk2 but same dimensions as mk1), and RV. You might have to do some work to make sure the horn contact works.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
The Following User Says Thank You to Ghostyman For This Useful Post:
Old 05-01-2010, 03:51 PM   #6 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
The AW11 and AE86 have the same steering wheel arrangement. The SW20, AE92 and newer have a shallower setup, so while the steering wheel will fit, it would sit closer to the driver, and your turn signal/wiper stalks would be further away from the wheel.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
Old 05-02-2010, 07:48 PM   #7 (permalink)
View bcp477's Photo Gallery
The steering shaft diameter, threads and splines are the same.... in fact, for all Toyotas. So, yes, the wheel will actually fit on your steering shaft. However, as others have said, the ergonomics with that wheel may or may not be right. The only way to know is to try it.
I am using a similar wheel, from an '88 (if I remember correctly) Celica.....in my AE92 sedan. It works just fine.
bcp477 is offline   Reply With Quote
Old 05-02-2010, 07:56 PM   #8 (permalink)
Oh, I forgot to mention that the Celica wheel I am using definitely has less offset (shallower "dish") than the pictured MR2 wheel.....it is very similar in this respect to the original AE92 wheel.
Old 05-03-2010, 12:46 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
is the diameter smaller though?
I just want to find an OEM looking wheel that has a smaller diameter... the stock wheel is like a school bus wheel
'81 BMW R65
Old 05-03-2010, 05:15 PM   #10 (permalink)
No, the Celica wheel isn't smaller. About 380mm (15").....like all the other stock Toyota wheels I've seen. I'd prefer one of about 350....or even 320 mm myself, but I can live with this one.
Old 05-04-2010, 12:23 PM   #11 (permalink)
Rotary guy...
eage8's Avatar
Yeah, I have a 350mm on my rx-7 and I like it a lot. I think it's the perfect size.
'81 BMW R65
Old 05-05-2010, 12:13 AM   #12 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
What about a steering wheel from like.. a 2000+ Celica? :p
Createdtoburn is offline   Reply With Quote
Old 05-05-2010, 12:22 AM   #13 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Pretty sure that would work. I've seen them fitted to 7th gen Corollas in the past, so I assume they'd fit the 6th gens too. The Celica steering wheel is virtually identical to the one found on the Toyota Vitz RS/Echo T-Sport. Bear in mind that they're equipped with an airbag, which is what makes them rather pricey when buying from a wreckers yard.
Old 05-05-2010, 10:34 AM   #14 (permalink)
Yeah see I want one of those newer style Toyota steering wheels but I think almost all of them have airbags huh? And I dont need airbags lol.
Old 05-05-2010, 12:28 PM   #15 (permalink)
I originally intended to find a wheel from a newer model Corolla or Matrix for my AE92 sedan (and remove the airbag)....but I found the Celica wheel first....and it was only $8.00 at the junkyard. With a good leather cover added, it does for me.
