so does anyone have a problem when starting their corolla when its cold it seems to take awhile to crank over but when it is warm starts fine, it has a brand new starter
If you are talking about a fuel injected motor:
Yes I do also. I believe my problem stems from the cold start injector. I exchanged it out once for a different one and it got better, but now its back to the same way. I think if I clean out the intake manifold of all the sooty gunk, it will get better but we'll have to see.
If it's a 4AF (carb), pump the pedal a couple times before you start it. Anytime it takes more than 2 revolutions to start, I give it a little gas and it fires right up.
For 4AFE/4AGE (EFI), the Cold Start Injector is often the cause (as noted above).
But I guess the most important question is: how long does it take to start? It could be normal.
I HAD the problem before, I used to crank it for about 4-5 seconds for the thing to start in the cold. I just replaced all the temperature sensors and it started right up.
I don't have any problems starting mine anymore though, the "beast" starts like a dime. I do love my 390k mi. Corolla, I'm actually surprised the thing passed the smog check here in Cali. Anyways GL on fixing it.
its fuel injected forgot to mention that. so i guess i could check the cold start injector to make sure it is working properly and then go from there huh
Also check the cold start timer.
It is the brown water temp sensor on the front of the thermostat housing, under the distributor.
That regulates the cold start injector
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
what do i check on it besides the obvious broken/unplugged?
There is a resistance check. The manual gives details.
