carb rebuild kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2010, 09:37 PM   #1 (permalink)
View jessicool's Photo Gallery
carb rebuild kit
Hi I have an 89 corolla with a 4 AF engine. I have been having problems with the carbueretor. I can't seem to find a carb rebuild kit online for an 89 corolla. Can anyone point me in the right direction in finding a carb rebuild kit? thanks in advance
jessicool is offline   Reply With Quote
Old 05-13-2010, 09:55 PM   #2 (permalink)
View Angel13's Photo Gallery
You should go ask at a auto parts i found mine at an auto parts.
Angel13 is offline   Reply With Quote
Old 05-14-2010, 05:27 PM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
AE92
You can look on eBay. The primary brand of carb rebuild kit is Keyster, comes in an orange box with black letterings. Has everything you need; gaskets, ball bearings of various sizes, springs, float, adj. screw, etc. They're about twenty bucks.
I did a rebuild on the carb I'm running and it has been good since! I had unknown problems with it before.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
The Following User Says Thank You to SCT For This Useful Post:
jessicool (05-28-2010)
Old 05-14-2010, 06:27 PM   #4 (permalink)
ebay
so i found this on ebay and im pretty sure it will work with my car but i want to be sure because it says this is a one barrel carb and i thought the stock one on my car was a 2 barrel?
well here is the carb
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
does anyone know if this will work for my car? my car doesnt need to be super fast just fuel efficient and working. thanks in advance
Old 05-14-2010, 07:56 PM   #5 (permalink)
SCT
iAzn
SCT's Avatar
That's a 2 barrel, not one. It looks exactly the same to me.
Old 05-15-2010, 06:34 PM   #6 (permalink)
verlaryder's Avatar
View verlaryder's Photo Gallery
What carburetor problems? 95% of the time these rebuild kits are not needed and will not fix the problem because the real problem is external (leaking diaphragms or failed solenoids that are attached to the carburetor).
verlaryder is offline   Reply With Quote
Old 05-19-2010, 02:14 AM   #7 (permalink)
carb problems
well when I try to accelerate in my car sometimes it doesnt work right and it is like starving for gas but if you press on the gas pedal just a little bit you can get it to accelerate but you have to go pretty slow to get up to speed. also my car wont shut off when you turn it off I have to put it in gear and let off the clutch to stall it. also my car is extremely loud and is getting not so goood gas mileage. I have recently replaced the exhaust manifold distrubutor cap, wires, plugs, air filter, catalytic converter, and o2sensor. I think its the carburetor because it works great sometimes but sometimes it feels like its starving for gas and it will jerk my car back and forth a lot when you try to accelerate.
I plan on ordering the carburetor from ebay tomorrow unless someone thinks it is a different problem?
Old 05-19-2010, 02:33 AM   #8 (permalink)
verlaryder's Avatar
There should be plenty of '89 Corollas in your local self service auto wrecking yards. Get a carburetor from one of those cars.
Old 05-19-2010, 03:34 AM   #9 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Some other items that could cause your problem would include EGR valve, fuel pump, vac line leaks. Your car has alot of vac lines so check em all for leaks. Also the distributor has centrifical weights and springs inside it at at the bottom. I found mine rusty and stuck in place (they should spin out freely). I cleaned them up and that made car run much better. The fact that your car has the dieseling problem (continues to run when shut off) sounds more like a vac leak problem.
90 GP is offline   Reply With Quote
Old 05-19-2010, 03:47 PM   #10 (permalink)
thanks for all the advice. At first when i started having problems with my car people thought it was the timing belt so right now the timing probably isnt perfect and that is why I thought it kept running after I turned it off. How do you check for vaccum leaks? I dont know a lot about cars and everything I know is what people have done to try to fix this car.
