the right superpro poly bushings for ae92 gts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2010, 10:07 PM   #1 (permalink)
rdyzz's Avatar
Gameroom cash: $137500
View rdyzz's Photo Gallery
i just ordered some poly bushing from R-sport international. these all are the right ones and fit. due to lack of info on the hub bushing or "outter bushing" 0825k is not the right part. instead 1039k is the right part for the 88-91 corolla gts coupe with disc brakes. i can only speak for the disc brake model. i have owned two ae92 that i installed these in a 88 and a 90. note that the 88-89 have large rubber bushing for the lower hub, where as the 90-91 changed to a internally greased bearing type. the 90-91 is a large metal sleave that is pressed in so it actually looks like the bushing for the 90-91 is very small when in fact after you press the sleave out it will indeed accept the same bushing size the 88-89 will witch is again pn 1039k. here is a list of the pn i ordered and price from r-sports as of may 2010.
SPF0823K SuperPro SPF0823K GMH, Toyota Tr/Arm Bushing $64.40
1 SPF1039K SuperPro SPF1039K Toyota Seca AE93 R/con arm out $64.40
1 SPF1040K SuperPro SPF1040K Toyota Seca AR93 Rear con/arm $60.20
1 SPF0996K SuperPro SPF0996K Toyota Corolla AE 95 Front Low $30.10
1 SPF1370AK SuperPro SPF1370AK Toyota Corolla AE 90,92,93,95 $44.10
1 01freight 0002 Freight $22.00
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
The Following 3 Users Say Thank You to rdyzz For This Useful Post:
canadianae92 (05-27-2010), Donald (05-26-2010), eage8 (05-10-2011)
Old 05-24-2010, 11:53 PM   #2 (permalink)
SuLLiVaN88's Avatar
Gameroom cash: $122837
View SuLLiVaN88's Photo Gallery
sweet man i will definetly be using this when i go to order my bushings.
sucks we have to piece it together instead of them having a kit we could order
PICKUP PARTS!http://www.toyotanation.com/forum/showthread.php?p=3351792#post3351792
SUPRA PARTS!
http://www.toyotanation.com/forum/sh...d.php?t=360413
SuLLiVaN88 is offline   Reply With Quote
Old 05-25-2010, 07:15 AM   #3 (permalink)
BackYard Engineering
Evo_lucian's Avatar
Gameroom cash: $102535
View Evo_lucian's Photo Gallery
The ae86 guys have it so good, kits are all over the place for them. Thanks for the part numbers bro
The only thing in life worse than being talked about is not being talked about
My website updated 6/May/11
http://budgetracer.webs.com/
Evo_lucian is offline   Reply With Quote
Old 05-25-2010, 09:05 AM   #4 (permalink)
SuLLiVaN88's Avatar
[quote=Evo_lucian;3206396]The ae86 guys have it so good, kits are all over the place for them. Thanks for the part numbers bro[/quote
we are the dam stepchild to the ae86 lol
SUPRA PARTS!
Old 05-25-2010, 10:00 AM   #5 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
I know a guy who autocrosses an AE86 and he says good parts for it are really hard to find. most of the parts being made for it are just junk.
'81 BMW R65
Old 05-25-2010, 11:06 AM   #6 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
This should go into the sticky part number thread...
SuperRA is offline   Reply With Quote
Old 05-25-2010, 01:18 PM   #7 (permalink)
SuLLiVaN88's Avatar
agree cause it will be buried in threads by the time i go to order my bushings
sticky it up lol
SUPRA PARTS!
Old 05-26-2010, 04:22 PM   #8 (permalink)
Evo_lucian's Avatar
At least they make junk for it. We dont get squat
Old 05-26-2010, 05:21 PM   #9 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Thanks. I have copied and saved for future reference.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 05-26-2010, 08:21 PM   #10 (permalink)
Gameroom cash: $100900
View 4doorGTS's Photo Gallery
Scroll down they are all clearly laid out here as well.
http://www.toyheadauto.com/Performan...a_1966_to_1970
WTB: Rear TRD sway bar for ae92
4doorGTS is offline   Reply With Quote
Old 10-19-2010, 04:30 PM   #11 (permalink)
View beedlo's Photo Gallery
Thanks to you, I just had those bushings put into my '90 GTS.
beedlo is offline   Reply With Quote
Old 10-19-2010, 04:31 PM   #12 (permalink)
Rotary guy...
eage8's Avatar
this should be a sticky...
'81 BMW R65
Old 03-30-2011, 04:29 PM   #13 (permalink)
Rotary guy...
eage8's Avatar
I just want to bump this thread again... I was recently looking into these and r-sportinternational.com is amazingly cheap... like 2/3s the price of tein which is the NA distributor....
'81 BMW R65
Old 05-16-2011, 09:57 AM   #14 (permalink)
Rotary guy...
eage8's Avatar
I just installed the rear bushings over the weekend and just a heads up. If you have drums, the inner bushing kit isn't correct. The bushing on my SR5 lateral link for the front links was smaller in diameter.
luckily there was a GT-S in the junkyard and I just took it's subframe and the 2 front links it had. I already had GT-S rear links for my disc brake conversion, but I think the inner bushings for those are the same.
Also, be careful if you have 90-91 rear discs with the metal sleeved bushings in the knuckle. I actually bent one of my knuckles pressing them out... luckily I had an extra lying around. you need to support the arm when pressing out the bushing, it should be pretty easy to see what i'm talking about.
'81 BMW R65
