it could be bad afm, bad connection to afm, bad dizzy or coil/igniter. does it misfire alot. if it does its prob a ignition based problem. it might help to spray the manifold area with break cleaner or somthing that will raise idle if you have a vacuum leak. does it die when your driving or when you do stop and go?
also a bad coolant temp sensor can cause the car to hesitate too.
without actually hearing the engine and seeing it happen its kinda hard to help.
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
