I think ae92 4afes used the 200mm flywheel and ae101 moved to 212mm. I believe the measurement is dia of the friction surface... could be wrong, I never measured the different flywheels i have. I do know that all 4afe flywheels are the same actual size when it comes to the ring gear. You won't cause any problems by fitting the larger flywheel, it has the same tooth pattern for the transmission input shaft and it is virtually completely the same other than clutch surface wise.
The newer years including models with the 7afe use the flywheel with the bigger clutch but they have virtually the same transmission. The interchangeability is nice.
The clutch hydraulic system should be fine.
