Spark plug types.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2010, 07:07 AM   #1 (permalink)
View jbrdbr111's Photo Gallery
AE92 Spark plug types..
Ok so getting ready to replace all my plugs and wanted to know if I should go with oem, or one of the 4 prong plugs. I want a little more performance/mpg , well especially more mpg if these 4 prongs will help any?
Also when I check autozone for wire sets it shows them as coming with the distributor cap, so should I change the rotor as well?
Trying to get by as cheap as possible, without being TOO cheap on my cars performance.. Any tips or advice regarding this stuff would be greatly appreciated..
jbrdbr111 is offline   Reply With Quote
Old 06-03-2010, 07:22 AM   #2 (permalink)
on full afterburner
Gameroom cash: $1346597
Stick with Denso or NGK for spark plugs. OEM replacements should be more than enough.
Old 06-03-2010, 09:46 AM   #3 (permalink)
thanks, should I replace the rotor while I'm at it too?
Old 06-03-2010, 12:06 PM   #4 (permalink)
SuLLiVaN88's Avatar
Gameroom cash: $122837
View SuLLiVaN88's Photo Gallery
ya might as well a rotor should be like 10 dollars or less
PICKUP PARTS!http://www.toyotanation.com/forum/showthread.php?p=3351792#post3351792
SUPRA PARTS!
http://www.toyotanation.com/forum/sh...d.php?t=360413
SuLLiVaN88 is offline   Reply With Quote
Old 06-03-2010, 01:08 PM   #5 (permalink)
Got some issues here.. Went to take off distributor cap, it was so old and worn that it busted the plastic attachment to the ignition coil, and the rubber seal was dry rotted.
The coil was cracked upon further inspection. Will this be hard to replace as well?
Old 06-03-2010, 02:44 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Only misfiring sparkplugs worsen the MPG, working sparkplugs wont have any effect on mpg. 4 prong plugs dont do anything except increase plug change interval.
Old 06-03-2010, 04:08 PM   #7 (permalink)
SuLLiVaN88's Avatar
you should be able to get the coil from auto parts store or maybe ebay.. and the rubber seal is like and o-ring i found one for my car at checkers it came in a set of different size o rings
SUPRA PARTS!
Old 06-04-2010, 07:04 AM   #8 (permalink)
Ok got it all replaced, couldn't find any stores that carried the rubber seal, so I just shoved cut up parts in the gaps for the time being.
Edit: also first spark plug was drenched in oil, but the rest were fine. What does this mean, and what can I do?
Old 06-04-2010, 10:12 AM   #9 (permalink)
SuLLiVaN88's Avatar
sounds like your valve cover gaskets could be leaking i doubt you would get enough blow by from the rings to drench your plug
SUPRA PARTS!
Old 06-04-2010, 10:44 AM   #10 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
you do, I've had the same thing happen to me.
you need new spark plug tube grommets and a valve cover gasket.
'81 BMW R65
Old 06-04-2010, 11:09 AM   #11 (permalink)
Is that gonna cost me an arm and a leg?..lol
Old 06-04-2010, 01:08 PM   #12 (permalink)
Rotary guy...
eage8's Avatar
http://shop.advanceautoparts.com/web...S_964082163___
$26 at advance auto.
'81 BMW R65
Old 06-04-2010, 01:18 PM   #13 (permalink)
SuLLiVaN88's Avatar
nope only an arm lol
SUPRA PARTS!
Old 06-04-2010, 01:22 PM   #14 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Happened to me as well. The grommets around the spark plug tubes are leaking. Its a pretty easy job, relatively inexpensive. Make sure when you tighten the nuts back down on the valve cover, don't overtighten, the little rubber bit on there can tear very easily. Its only a little to torque them down, on the matter of inch-pounds.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 06-04-2010, 05:00 PM   #15 (permalink)
teh pwnager
View Rabbitbunny's Photo Gallery
Just wanted to correct this since it came up, no point in letting members read bad information.
Plugs with a weak spark, or plugs with a wide gap, will ruin mileage. Plugs don't misfire. Two or Four prong plugs are mostly a gimmick, especially in a Corolla. Regular copper plugs will be the best performer, so don't buy the "better" ones they're trying to sell you, they're not better. Also, their change interval is longer in a correct application, but since they're wrong for a Corolla they will quickly become entrenched in carbon deposits. Knowing the 'why' is always the important part, not just memorizing what you've heard
Rabbitbunny is offline   Reply With Quote
