AE92 4age flip light problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2010, 11:19 AM   #1 (permalink)
View Gavinator1192's Photo Gallery
Hi, one day my driver side headlight would not flip open. I looked at the arm joint and it was loose, so i tightened the bolt that connects the arm to the hydrolic. Now the driver side headlight will not flip open as high as the passenger side light, about two inches lower and it makes a major difference on the road. Ive tried loosing the bolt again and readjusting the height then tightening again, but still no difference. Its not catching as it does the same thing when the hood is up, and the weird thing is when i turn them off the driver side light flips up two inches to where it SHOULD have been and then goes down.
When i manual adjust it with the hydrolic twisty it will reset itself to the bad position when i change any settings.. IE. brights, turn off, turn on.
So my question is there any way to reset the headlights?
Or ANY suggestions is appreciated.
Gavinator1192 is offline   Reply With Quote
Old 06-08-2010, 12:05 PM   #2 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
The manual twist knobs are just for cases when there is a loss of power or for whatever reason you can't raise the flip ups under power. They are not used for adjustment.
It sounds like you have a dead spot in the motor itself. I can't remember if they are serviceable and can be opened up. If they can, it would probably just be some worn contacts inside. Might be easier to find a replacement motor though.
91 rolla GTS - 89 rolla GTS - 90 rolla SR5 - 90 rolla Sedan - 67 Ford Galaxie 428 - 69 Olds 442 - 80 Custom Bronco (38" meats) - 68 Mustang - 86 5.8L Cougar - 89 Mustang...the list goes on.
RED91SR5 is offline   Reply With Quote
Old 06-08-2010, 12:14 PM   #3 (permalink)
Gameroom cash: $102920
View 90celica's Photo Gallery
I wonder if they are the same as the 5th generation celica?
1990 Celica GT - work in progress
1994 Tercel
90celica is offline   Reply With Quote
Old 06-08-2010, 04:05 PM   #4 (permalink)
okay i will start looking i guess . its the weirdest thing because when i turn them off they flip up to where they should be then immediately go down..
Old 06-08-2010, 04:43 PM   #5 (permalink)
RED91SR5's Avatar
I guess you could plug it into the other side harness and test and see if it does the same thing. Then you'd know for sure that it's the motor that needs replacing. You obviously have to take the motor out to do this.
Old 06-08-2010, 05:52 PM   #6 (permalink)
SuLLiVaN88's Avatar
Gameroom cash: $122837
View SuLLiVaN88's Photo Gallery
and if you do end up replacing it im pretty sure the mk1 mr2 and mk3 supra's use the same motor
PICKUP PARTS!http://www.toyotanation.com/forum/showthread.php?p=3351792#post3351792
SUPRA PARTS!
http://www.toyotanation.com/forum/sh...d.php?t=360413
SuLLiVaN88 is offline   Reply With Quote
Old 06-08-2010, 09:49 PM   #7 (permalink)
Okay thanks guys!
hate to do all of the work but i do love my car <3
Thanks
