Idle / Electrical Problem - Oil Smells like Gas
For a couple months now I've noticed that when I turn on any electrical device in my car, the engine idle drops to about 500 and the car shakes. If I'm driving its not noticeable due to the higher revs, but if I'm at a light or sitting still it is very noticeable.
I have also noticed that my headlights when on are oddly dim and will drop the revs, so I have to always run with them on bright, which is still not very bright...just average.
So, in the last month this idle problem has become worse. I replaced the alternator, thinking it was the source of the problem, it has absolutely ZERO effect on it.
Yesterday I go to change the oil, and as soon as I popped the drain plug out, it was a very very strong smell of gas. The engine was hot, I'm sure that made the smell worse. When I removed the fill cap, and stuck my nose to the fill hole, it smelled of sulphur. Not too bad, but distinct.
What is my problem, or what can I do to diagnose it? I'm on a budget. Could it be as easy as new plugs, wires, distributor? Or should I be looking at a new set of injectors? =(
91 Sprinter Carib All Trac - AE95 4A-FHE - RHD @ 142,000km (88,000mi)
89 Corolla [Carib] JDM - All Trac - AE95 4A-FE - RHD - Murdered by T-Bone @ 224,000km (139,000mi) - R. I. P.
