car wont start 3 sensor failure!!! wtf - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2010, 08:47 PM   #1 (permalink)
View 4dRcOrOlLA's Photo Gallery
so my car didnt start a couole times and i decided to pull the codes it came up to 12, 22, and 24 which is speed sensor(rpm signal) , intake air temp, and coolant temp sensor. what will trigger all 3 of these sensor or i just need change all 3 of them.wen this happen my car wont start but will if i wait 10 min or so thanks
ps can i take these sensor from the ae101??
4dRcOrOlLA is offline   Reply With Quote
Old 06-24-2010, 09:42 AM   #2 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
I would start by checking wiring harnesses and connectors for corrosion etc. which could be causing bad signals to the ECM.
I doubt the AE101 is the same stuff but someone else can maybe answer that.
91 rolla GTS - 89 rolla GTS - 90 rolla SR5 - 90 rolla Sedan - 67 Ford Galaxie 428 - 69 Olds 442 - 80 Custom Bronco (38" meats) - 68 Mustang - 86 5.8L Cougar - 89 Mustang...the list goes on.
RED91SR5 is offline   Reply With Quote
Old 06-24-2010, 04:14 PM   #3 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I agree.
Start by checking the manual to see if there is a connector that has all three of those wires in it.
Some of the AE101 sensors are the same, but I am not sure about those particular ones.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 06-24-2010, 05:32 PM   #4 (permalink)
well i checked and it seems oil or coolant got into the coolant temp sensor plug im gunna clean tha up and c wat happen thanks i guys
Old 06-25-2010, 01:50 PM   #5 (permalink)
Gameroom cash: $134355
in AW11's if you get the "3 lights of death" it's due to an alternator.....
so, other than figuring out why you have the codes you should be a bit more specific...
is it cranking and not starting? Will it not crank? What have you checked (besides the stored codes)? What have you tried to do?
Old 06-28-2010, 06:19 PM   #6 (permalink)
well wen this happen it cranks but wont start and it always end up startin after 10 min or so, so never really bother with it since it happen like 3 times in the past 6 months. well i clean up the plug and reset the ecu or ecm lets wait c what happens
