oil catch can - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2010, 05:55 PM   #1 (permalink)
View ae92boy's Photo Gallery
oil catch can
how do i install a oil catch can to the stock motor of the 1990 corolla sr5.
ae92boy is offline   Reply With Quote
Old 07-02-2010, 06:27 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Where do you want to catch oil from?
SuperRA is offline   Reply With Quote
Old 07-02-2010, 06:41 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
if you're running a stock engine with the stock PCV system, you dont need a catch can and you dont want one either as most of them are vented. Therefor your PCV system would suck air through the catch can vent and into the intake, thus creating a vacuum leak.
and since you live in california, doing that would be illegal
Old 07-03-2010, 12:29 AM   #4 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
the catch can should be connected to the pcv outlet on your valve covers and then connected to the intake manifold or intake runners, or just vented to atmosphere with a filter, or exhaust, all of it is probably illegal in cali
canadianae92 is offline   Reply With Quote
Old 07-03-2010, 01:31 AM   #5 (permalink)
um it was a graduation gift. um you think someone can draw a diagram of the valve cover cause idk which is the pcv valve on there. since there are two hose on it
Old 07-03-2010, 03:30 PM   #6 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Here's a DIY from the 7th Gen Corolla section. Should be the same procedure for your 6th Gen:
DIY Oil Catch Can Installment Corolla 93 - 97
Old 07-03-2010, 04:40 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Without a catch-can, all that oil/carbon gunk builds-up on the tips of the injectors and can cause pre-igntion (pinging) over time.
I read the 7th gen write-up and thats pretty much wrong. The pintle stays fairly clean due to the cleaning agents in fuel, it wouldnt cause much issues and the same cleaning effect with the swirl of the intake air keeps the cylinders quite clean and wouldnt cause pinging. Pinging can be caused by a badly done catch can tho. A 4A-F/FE doesnt have that much compression to cause pre ignition with some carbon particles, also with modern cylinder heads thats really not going to happen. I can see that happening in side valve heads of yester year or something like that.
I'd say that the EGR is alot worse than the PCV. My 4A-F which only had a pcv stayed quite clean intake wise, but the 4A-FE intake manifold I got was filled with shit, but that was from the EGR. Still, it wouldnt really matter that much, most cars still function quite well even tho they've never been attended to other than the basic maintenance. You should really see a high mileage corolla... I mean something with 300,000-500,000km on the odo, they still work fairly well.
I'm all for catch cans on cars that need them, such as cars that run no PCV system and need to have it for track use. I just have two hoses on my car going to the ground... lol
Old 07-04-2010, 01:17 PM   #8 (permalink)
does this look any bit correct to you guys.
on the white part i blocked off that and added a air breather.
blue and yellow are the hose running to the oil catch can.
Old 07-04-2010, 02:11 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Yeah, looks fine..
Old 12-29-2010, 11:39 AM   #10 (permalink)
RogueMoog's Avatar
Gameroom cash: $313930
View RogueMoog's Photo Gallery
Originally Posted by ae92boy View Post
A bump, a question... looking at this pic, can you plug off the white circled parts (VC, TB) instead of using a breather? And can you place a breather filter on the PCV valve instead of using an OCC? I'm guessing the latter would require regular cleaning of that breather filter.
After seeing all the crap in my engine's intake from the oil getting into the air/fuel mix, I'd love to do away with the PCV -> intake.
RogueMoog is offline   Reply With Quote
