4AGE water pump pulley dimensions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2010, 04:12 AM   #1 (permalink)
View mitman's Photo Gallery
Hi all,
can some body tell me these dimensions of water pump pulley for 4AGE (part no. 16371-16030):
Hole spacing ?
Size of central hole?
Hole distance from center?
Thanks MiTMaN
mitman is offline   Reply With Quote
Old 07-12-2010, 12:49 AM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Approximately 112mm Dia (my calipers weren't big enough, i approximated the radius and doubled it)
with a 32mm center hole
on a 40mm square bolt pattern centered on center hole. (calculate distance to center, it'll be more accurate)
hole distance from center calculates to 28.3mm
assume the bolt hole diameters are clearance holes for M6 (mines was already bolted on)
Luckily I had an engine sitting in the garage on a stand.
Mind me askin whacha doin?
SuperRA is offline   Reply With Quote
Old 07-12-2010, 03:36 AM   #3 (permalink)
SuperRA: Thank you man a lot thx, thx, thx you save my life
Im going to make new water pump pulley with smaller dia for my 4AGE 20V (i want to do test drive in this sunday ;o) )
Old 07-12-2010, 10:15 AM   #4 (permalink)
Well, just a warning, I don't know what part number it was, I couldn't see it. Also my engine is a smallport 4AGE. So hopefully they are the same water pump pulley as the 20v.
Old 07-13-2010, 04:14 PM   #5 (permalink)
Gameroom cash: $134355
there are at least 3 different 4age water pump pulleys...... and the 4/7afe pulleys are different from those as well....
