Pan questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2010, 02:43 PM   #1 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Pan questions
1988 Toyota Corolla, 4AF
What size allen wrench is need for the drain bolt on the auto transaxle oil pan?
It is a 10mm allen........
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 07-12-2010, 04:49 PM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
What size allen wrench is need for the drain bolt on the transaxle (gearbox) oil pan?
it's not an allen wrench bolt, it's just a regular hex bolt. I think it's a 21mm or maybe a 24mm? I forget... jack up your car an measure it
'81 BMW R65
Old 07-12-2010, 04:58 PM   #3 (permalink)
Mr.Nutcase's Avatar
No, I mean on the oil pan......... the drain bolt.
It is a allen, 10mm allen...
Old 07-12-2010, 05:03 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
I remember it is an allen,
automatic or manual?
you said oil so I assumed it was a manual...
'81 BMW R65
Old 07-12-2010, 06:44 PM   #5 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
It's an automatic, I remember having drained my old automatic before; Manuals don't have oil pans; And it's trans fluid in automatics, not "oil" or gear oil. I believe it's a 10mm Allen, I suggest using allen sockets.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 07-12-2010, 09:03 PM   #6 (permalink)
Mr.Nutcase's Avatar
When I got there I tried my 10mm allen wrench, it fits.....
When I torqued the drain plug 36 ft pounds.....
the fill bolt for the diff, what size is it?
Old 07-12-2010, 09:12 PM   #7 (permalink)
Mr.Nutcase's Avatar
fluid pan.. does not sound that good..... oil pan sounds better....
Old 07-12-2010, 11:38 PM   #8 (permalink)
SCT
iAzn
SCT's Avatar
It may, but it can be confused with the engine's oil pan if you don't say tranny oil pan.... whatever.
Yea, the diff bolt is 24mm, on the diff case cover that's closest to te firewall. Don't let the diff go dry, I had that problem and resulted in my gears losing their spacers or washers and jammed everything.
Old 07-13-2010, 02:36 PM   #9 (permalink)
Mr.Nutcase's Avatar
What the best way to fill up the diff?
Old 07-13-2010, 03:13 PM   #10 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Asking your question in multiple places won't get it answered any faster... it actually may get answered slower in that it gets annoying to see the same question in different posts.
To fill the diff, buy a gear oil pump and put it on the ATF bottle. Stick the pump hose in the hole and start pumpin till it leaks out. Then put plug back in the hole and be happy.
SuperRA is offline   Reply With Quote
