gas out of #1 exhaust - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2010, 02:54 PM   #1 (permalink)
View brawler's Photo Gallery
89 4 door 4a-c and runs real rough,and on 3. I started digging and found that unburnt gas was coming out and pooling at exhaust port 1.all others fired right,but this one wont.compression is good.the plugs and wires sparked too.its getting gas obviously. I'm at a loss. any help? Thank you in advance.
288,xxx miles. maybe valve guides in #1 are shot more than the others? some smoke,but not too much. not bad for the miles on her.
brawler is offline   Reply With Quote
Old 07-31-2010, 03:02 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I think the auxillary accellerator pump vacuum tube goes to #1 intake port. If the diaphram in the AAP goes bad, you will get raw gas into #1 that will cause missfire and poor fuel economy.
Check that vacuum line and see if gas comes out of it. If it does, the diaphram on the carb is bad.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 07-31-2010, 03:11 PM   #3 (permalink)
going to try in a little while.waiting on heat to subside. Thank you very much
Old 08-01-2010, 07:21 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
89 4dr sedan would have a 4AF not a 4AC
