ae-92 suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2010, 10:30 PM   #1 (permalink)
AE-92-4A-Ge
gmboy's Avatar
View gmboy's Photo Gallery
AE92 ae-92 suspension
i have been told that honda civic suspension (springs and struts) can be used on the front and the rear of an ae-92. has any one done this or knows if it is possible. my car sits a little high the the 17" tires and the front is getting quite spongy.
marshall
gmboy is offline   Reply With Quote
Old 08-02-2010, 11:27 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Seems kind of wrong to me. What year civic are we talking about. Most of the 90's and older civics have a double wishbone front suspension which I wouldn't think is too compatible with the macpherson strut suspension the AE92 has.
SuperRA is offline   Reply With Quote
Old 08-03-2010, 09:56 AM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
no, they don't fit.
why don't you just get springs and struts made for the corolla?
'81 BMW R65
Old 08-03-2010, 10:11 AM   #4 (permalink)
AE-92-4A-Ge
gmboy's Avatar
i can't find any good suspension for the ae-92 any where in canada on websites. crossed it and everything. i have a friend with civic front suspension on his but not sure how much work it would be to convert.
Old 08-03-2010, 10:43 AM   #5 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
yeah, why not just get the parts made for your car? you can get them anywhere, if its's regular transportation car, just get regular parts... even the regular parts are about $200.00 and they can charge up to around $800 to $1000 installed.. for stock suspension (Struts only..)
In the USA..
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 08-03-2010, 11:30 AM   #6 (permalink)
Rotary guy...
eage8's Avatar
what year civic are you talking about and what are you plans for the car?
and what kind of budget are you on...
'81 BMW R65
Old 08-03-2010, 11:56 AM   #7 (permalink)
AE-92-4A-Ge
gmboy's Avatar
low budget :P its an everyday driver for the summer. i am looking for a tight strung suspension. not sure what i will do yet. im going to check altrom for somthing that may be shipped from the states.
Old 08-03-2010, 12:17 PM   #8 (permalink)
Rotary guy...
eage8's Avatar
I'd probably just go with eibach springs on KYB GR-2s then
'81 BMW R65
Old 08-03-2010, 02:49 PM   #9 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I second that.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 08-03-2010, 10:34 PM   #10 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Yeah... and VTEC hits at 3500rpm on Corollas.
Old 08-04-2010, 04:46 AM   #11 (permalink)
Question
whatever that is, what does it have to do with struts?
1993 Camry LE
Old 08-04-2010, 09:19 PM   #12 (permalink)
KDM is in
REN69's Avatar
VTEC is a Honda system... Honda springs on a Corolla... VTEC on a Corolla... meaning two things that don't mix... nvm.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 08-05-2010, 03:23 AM   #13 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I wouldn't doubt someone somewhere has done some heavy modification like that to an ae92's suspension. But I would thing it would be easier to stick with the stock suspension. Changing the type of suspension like that would have you spending A LOT of the time working out the various angles and such just to make it work right without completely ruining the feel of the car. It would probably be easier to take the drive terrain out of your car and shove it in a Honda than change suspension types.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 08-05-2010, 07:21 AM   #14 (permalink)
rdyzz's Avatar
Gameroom cash: $137500
View rdyzz's Photo Gallery
you would need to somehow adapt the doublewishbone thats from the honda. it will not be cheap to have a fabrication shop do it. no the shocks and springs will not work without modifacation to the suspension. civic shocks are not designed to hold the side load of the toyota mcpharson setup. not just that but toyota struts bolt onto the spindle creating a upper povioting point/control arm where as the honda coil/shock bolt onto the lower control arm via 1 bolt and just provides damping due to it haveing two control arms.
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
Old 08-05-2010, 10:27 AM   #15 (permalink)
View yngtunr's Photo Gallery
just buy a full set of gr2 on ebay for 250 shipped and get some eibach pro kit for 200
thats basically 500 for full suspension and the rebound on the gr2 is amazing...very tight yet not too aggressive for daily driving....that paired with the pro kit is a 1 inch drop all around and a stiffer progressive driving spring...tighter corners smoother highway driving and still comfortable enough for daily driving with no problems whatsoever
you can rent a spring compressor from your local parts store for 50 bucks or so and if you are mechanically inclined at all you should be able to swap them yourself all in under an hour....put the eibachs on the gr2 and you would love it
yngtunr is offline   Reply With Quote
