Yep, sounds like a vacuum leak somewhere. I just went through this with my Celica. You can try spraying carb cleaner at various suspect places to see if the idle smooths out. Try replacing all the vacuum lines and gaskets like the intake manifold gasket, carb base gaskets. If that doesn't work, rebuild the carb, and then if that doesn't work, replace it. Unfortunately for me I took it all the way to the end replacing the carb and it finally works right. I still don't know what was wrong with the original carb, but I'm going to blow it up to punish it for causing me all this frustration.
