3 cylinders - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2010, 09:02 PM   #1 (permalink)
Corolla Tuner
SR5_GT-s's Avatar
View SR5_GT-s's Photo Gallery
Gen6 3 cylinders
HELP!!!!! my stock GTS with the 4af is only fireing on 3 cylinders, being a diesel mechanic i have almost no idea what to do with this problem on a gasoline engine. only thing i know is it may damage the cat, i looked at the sparkplugs and theyre all fine except in the cylinder that isnt fireing, its black and coverd in carbon. could it be loss of compresion or a cracked head gasket over that cylinder? is it ok to drive? anny answers will be apreciated.
1988 SR5, Factory red(yes its the origional paint) with carbon fiber hood,4agte BT swap, GodSpeed Ebay turbo kit, full 2 1/4" T-304 stainless exhaust to and HKS Spec D resonator muffler.
SR5_GT-s is offline   Reply With Quote
Old 08-19-2010, 04:37 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
if its EFI, then its also possible that the particular injector isnt firing. Also check the distributor cap if theres a terminal in the cap thats broken, also check the resistance of the plug wire. Def, replace the plug (might wanna replace them all while you're at it).
and while you're at it a compression check wouldnt be bad either.
Old 08-19-2010, 06:30 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
GTS never came with the 4AF... you sir have an SR5.
GTS ONLY came with the 4AGE EFI motor... never with a carb'd motor.
