need some ideas for porformance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2010, 04:46 AM   #1 (permalink)
View dj_watt's Photo Gallery
Hey all,
i am putting out a big challenge here, i am asking for some ideas on getting more out of a 4a-fc but there can be no turbos or superchargers.
what i was thinking of doing was either taking a 4a-ge or 4a-gz bottom recon it and then dump it in and then get a 4a-fc header and get that reconed but get the intake and exhaust ports bored out a bit. i think that might make it a 1.8L i might be wrong
any ideas???
thanks
dj_watt is offline   Reply With Quote
Old 08-23-2010, 11:57 AM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Originally Posted by dj_watt View Post
Hey all,
any ideas???
thanks
I doubt you are going to get much or any increase by switching the bottom end. All the power comes from the head. That being said, if you do some porting work on your current 4afc head, you should see some increase even if only a little. The header should help as well.
I believe you are mixed up a little. "Boring" or porting intake / exhaust ports in the head doesn't make the engine displacement larger. Only boring the cylinders and getting pistons to match or lengthening the crank stroke increase displacement. That costs $$$.
What I'd do: Do your head work and get your header and run it with your stock bottom. You'd be amazed at what some people here have squeezed out of it. If you do somehow manage to break it, then go for a 4AG bottom.
SuperRA is offline   Reply With Quote
Old 08-23-2010, 12:08 PM   #3 (permalink)
Joined the dark side. :D
Gameroom cash: $658191
View workerant's Photo Gallery
or how about throw that money in for a more performance vehicle? Like a Camry or V6.
Do a few weight lowering would help too.
workerant is offline   Reply With Quote
Old 08-23-2010, 01:37 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
LOL, I would classify a camry as a "more performance vehicle" My corolla is a lot faster than my fiancée's V6 camry
if you're set on keeping the 4A-F I would just put a header/exhaust on it and put some webers on it. But I think you'd be much better of swapping the engine to a 4A-GE, there is a good bit more NA power available.
here is a good site about NA mods:
http://www.billzilla.org/4agmods.htm
'81 BMW R65
Old 08-23-2010, 01:59 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
All the 4A series bottom ends are 1.6L so you will gain nothing by swapping in any of those.
If you want to go to a 1.8L you need the 7A-FE bottom end. It should bolt right up to everything you have now, except your exhaust pipe. The down pipe will probably need to be lengthened, since the 7A block is taller than the 4A block.
That will probably be the best $ value upgrade you could do to a 4A-FC.
While you are it it, you could probably swap on a Webber 32/36 carb too.
I really don't know if anybody has ever done that mod. I have never heard of it, but it seems worth the effort.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 08-23-2010, 02:02 PM   #6 (permalink)
I agree with this. Let me clarify my response. I'd only do what I said if I was bent on keeping the 4AF.
Old 08-24-2010, 01:32 PM   #7 (permalink)
on full afterburner
Gameroom cash: $1345597
A Camry is not a performance vehicle. It's a midsize FWD family sedan.
Old 08-24-2010, 01:48 PM   #8 (permalink)
^ the corolla I had when doing above 55mph it seem to be max out. While the Camry seem to have a little power left. And my V6 seem to be very happy doing above 70mph. And my V8, well.. it's a whole other vegetable.
So, by my personal experience with all the AT my Camry rate higher performance than Corolla, and they were both family sedan type. But the Corolla is a fun little car though.
Old 08-24-2010, 02:20 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
a big engine does not make a vehicle "a performance vehicle". it's a balance between power handling and lightness, a camry only has 1 of those things...
and my corolla has gone over 110... it's completely fine going 70...
'81 BMW R65
Old 08-24-2010, 02:52 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
it does? All I see is weight, average engine and family car handling...
Old 08-24-2010, 02:52 PM   #11 (permalink)
To me, yes the Camry is heavier than corolla but the power part seem to makeup the different and exceed a little.
performance = power (more) + weight (less)
but without turbo and supercharge U kinda cripple the 'power' part of the equation right? All U have is weight.
Old 08-24-2010, 03:14 PM   #12 (permalink)
LoL, I don't think your "Camry is better" argument is going to hold up here in the Corolla section of the forums...
Old 08-24-2010, 03:27 PM   #13 (permalink)
Fine, forget Camry... back on topic.
Old 08-24-2010, 04:19 PM   #14 (permalink)
Rotary guy...
eage8's Avatar
lol, the engine isn't terrible, probably a bit slower than my impreza and my corolla... but faster than a stock corolla :-P
'81 BMW R65
Old 08-24-2010, 06:19 PM   #15 (permalink)
Donald's Avatar
My V6 Camry wagon would make me smile (on the straights).
All it needed was a lighter better handling body.
Actually I've read somewhere that it is a better swap than a 3S-GTE, for the Gen2 MR2.
Just a bit more work to install.
I could go with that
