91 all trac wagon 3200 rpm @ 65mph - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2010, 09:14 PM   #1 (permalink)
View kobej05's Photo Gallery
i have a 91 corolla all trac wagon when im doing 65mph in 5th gear my rpm is at 3200 is that right?
kobej05 is offline   Reply With Quote
Old 08-25-2010, 09:26 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Sounds about right to me. The corolla's gearing is rather close
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 08-25-2010, 09:30 PM   #3 (permalink)
so im not sucking gas that way?
Old 08-25-2010, 09:40 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
that's much lower than mine haha. But I have a closer ratio transmission...
yes, that's fine
'81 BMW R65
Old 08-25-2010, 09:44 PM   #5 (permalink)
ok cool thats good to know i just got this car. also my other question is my wipers arent working i can move them by had but when i putt just one wiper the other moves to my question is it the wiper? i checked the fuse and its still good. how hard is it to replace the wiper motor? thanks
Old 08-25-2010, 10:53 PM   #6 (permalink)
The engine may be at a higher RPM, but also remember there isn't as much of a load on the engine at that speed so not as much fuel is used.
and if I'm reading your wiper problem correctly, when you turn your wipers on, only one moves?
Old 08-26-2010, 05:45 PM   #7 (permalink)
motor not working at all but i can move the wiper by and and it moves the other wiper with it. i checked the fuse and its still good. is it the relay maybe?
Old 08-28-2010, 10:36 PM   #8 (permalink)
correction the motor is working and the linkage sheered off the motor. so im gonna get another set from the junk yard and see if its the same from a regularr corolla. anyone know if there the same?
Old 08-29-2010, 05:24 AM   #9 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
The wiper linkage snaps onto the round stud on the motor. Sounds like you simply need to reattach it.
90 GP is offline   Reply With Quote
Old 08-29-2010, 08:25 AM   #10 (permalink)
View barthmonster's Photo Gallery
mine is off right now I need to pull the wiper motor and re-attach. Thanks for the info on this...
barthmonster is offline   Reply With Quote
Old 08-30-2010, 12:30 AM   #11 (permalink)
does anyone got pics of this? cause it looks like im missing parts here. all i have is the metal linkage.
Old 08-30-2010, 08:55 AM   #12 (permalink)
View nizzehult's Photo Gallery
Try here:
http://www.toyodiy.com/parts/p_E_198...MDKW_8501.html
nizzehult is offline   Reply With Quote
Old 08-30-2010, 11:58 AM   #13 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Those parts can wear out quite a bit. I would say check the junk yard for a wiper system that you cannot move much by hand. (very little free-play)
I just replaced a system on my sedan because the little plastic snap pieces and the matal balls in the linkage had so much play that the blades would swing completely off the glass onto the body. That car only has 109K miles on it.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
