88 4afe cooling fan stays on all the time... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2010, 07:19 PM   #1 (permalink)
plyr503's Avatar
View plyr503's Photo Gallery
Question 88 4afe cooling fan stays on all the time...
so my stepfather's 88 has an issue with the cooling fan staying on all the time, what are some common causes for this problem? I've already tried swapping out the fan relay just to see if that was an issue but it made no difference........something to do with the cooling system telling the car to turn it on maybe ? I haven't had much time to look at it yet..........
plyr503 is offline   Reply With Quote
Old 08-27-2010, 07:59 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
Coolant Temp Sensor.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 08-27-2010, 10:15 PM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
I would say coolant temp switch (not the sensor, there are different sensors for the fan and gauge) or it could be the AC high pressure switch.
'81 BMW R65
Old 08-27-2010, 10:20 PM   #4 (permalink)
plyr503's Avatar
good to know both are plausible this particular car is equipped with AC.
thanks for the info!
Old 08-28-2010, 10:37 AM   #5 (permalink)
theredae92's Avatar
View theredae92's Photo Gallery
have u figure out the main cause yet?mine is the same cooling fan on all the time..
Red 1989 Corolla AE92 - 4A-Fz -auto
Red 2002 Silvia S15 -SR20DET- 6speed- sold
silver 2002 Altezza SXE10 - 3SGE - 5AT Tiptronic
theredae92 is offline   Reply With Quote
Old 08-28-2010, 11:18 AM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
OR the socket is unplugged from the temp sensor... check that as well.
Old 08-30-2010, 10:19 PM   #7 (permalink)
plyr503's Avatar
it was the coolant temp switch. I had a hard time locating one because apparently they changed mid way through 1988, so , after paying 56.99 for the wrong one and returning it I went to pick n pull and got 5 for 2 dollars. The first one I put in worked perfectly and now I have four extras!!!
Old 08-31-2010, 09:40 AM   #8 (permalink)
theredae92's Avatar
AE92
cool man.. what its look like and where it is located?
Old 08-31-2010, 09:30 PM   #9 (permalink)
plyr503's Avatar
it's located on what looks like the thermostat housing just under the distributor. There are two electrical plugs coming from that housing it will be the larger of the two.
Old 09-01-2010, 12:01 AM   #10 (permalink)
theredae92's Avatar
any pic of coolant temp switch?
Old 09-01-2010, 06:24 PM   #11 (permalink)
plyr503's Avatar
location of engine coolant temp sensor
there is a pic in this thread and a picture of the location.....I'd take pics myself and post them but apparently swimming with your camera in your pocket is not recommended! the temp switch is the one with the blue end
The Following User Says Thank You to plyr503 For This Useful Post:
devo (09-02-2010)
Old 09-01-2010, 09:53 PM   #12 (permalink)
theredae92's Avatar
AE92
Old 09-02-2010, 10:49 AM   #13 (permalink)
devo's Avatar
View devo's Photo Gallery
Which one fits the 88 the blue one or the white one? I think mine is supposed to be white but they sold me a blue one???
devo is offline   Reply With Quote
Old 09-02-2010, 08:11 PM   #14 (permalink)
plyr503's Avatar
sounds like you are having the same problem I had. The blue one in that thread is for a later-1988 model and up. The parts store I went to first said that anything after june 1988 would use that particular blue one and anything before that a different coolant switch. My stepfathers car was manufactured in may of 88 so the switch looks like that except where the threads end is about as long as it gets, it's probably 3/4 of an inch shorter. Weird thing is, when I pulled all of those coolant switches out of the junkyard, no matter what 6th gen year corolla I pulled them out of they seemed to be the correct one for my car. It wasn't until I came across a geo prizm when I walked past the domestics on the way out that I pulled one of those longer ones in that photograph.
Oh and it depends on who you talk to and where you go as to what that blue switch is called, some places and people call it a fan switch (everywhere online almost) some call it a coolant temp switch (both auto parts stores I went to) The white sensor in that thread is a coolant temp SENSOR not a switch, I couldnt tell you from what year....
