Title says it all. The car is a 1989 sr5
The electric A/C clutch is not engaging when I push the button on the console. So I looked under the hood to see what was what and I found this wire which was slightly exposed:
I believe that that is the A/C clutch wire. The one with the fray in it is the power and the other is the ground just for info. I initially thought that this was the problem but so I carved a bit of the rubber away under the electrical tape there and tested for continuity which was good. So this area is not the culprit. I also thought that the compressor would be the problem since it has not worked for a while so I unplugged the above plug and applied 12v directly to that plug and the clutch kicked in. So there is a problem getting the signal through. When I push the button in the cabin the light also comes on so I think that it is still good. I also checked the fuse in the passenger kick panel and it was also good and surprisingly pristine looking.
Back to the button real quick. If it could be the problem despite the light coming on just fine when I push it, is there any way to get to it to test it without removing the instrument cluster. I looked today just in case and it looks like I will have to remove the entire dash.
I do not want to do this, so if there is a better way please let me know pictures also helpful.
The blue plug in this next picture goes to some part of the A/C system but I don't know what. Some clarification here would be helpful as well.
So my question for you guys is not what should I do next?
EDIT: If anyone needs other/different pictures I can run out and take some more.
