88 rolla wagon, a few questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2010, 03:58 PM   #1 (permalink)
View celica/camry's Photo Gallery
ok so i bought a 88 rolla wagon as a beater, then sold it to a friend that desperately needed a car and she agreeed to pay me to fix it up.
ive fixed the brakes and some other odds and ends now im going to tackle some other issues
shocks, i have a set of low milage shocks and springs from a 94 corolla i had, will they interchange with the 88?
rear speakers, after adding a factory radio/tape deck, i found there are no rear speakers, where would the wiring be for the rears for the wagon?
passenger rear quarter window, can i use one from a regular 4dr or is it wagon specific?
rear wiper, the factory arm is missing and there are no wagons in the yards, is there another model i can use a wiper arm from?
thanks
"i got a toy on sum alloys boy"
celica/camry is offline   Reply With Quote
Old 09-19-2010, 07:49 PM   #2 (permalink)
ELUSIV Rolla's Avatar
View ELUSIV Rolla's Photo Gallery
thanks
I think, I THINK, that the window will have to be off a wagon (pretty sure the windows have different angles), unsure on shocks, SHOULD be wires in the rear for speakers, have a poke around, if not, speaker wire is cheap and easy to run from the head unit to the rear, as for the wiper, just do some trial and error, fond one with correct spline then see if it works well on the window (too long, too short etc)
(ELUSIV)
ELUSIV Rolla is offline   Reply With Quote
Old 09-20-2010, 04:05 AM   #3 (permalink)
RogueMoog's Avatar
Gameroom cash: $313930
View RogueMoog's Photo Gallery
It might also depend on which wagon you're talking about... the regular FWD model or an All-Trac / 4WD model. The rear speakers on the All-Trac are located on the roof behind the back seat.
RogueMoog is offline   Reply With Quote
Old 09-20-2010, 11:57 AM   #4 (permalink)
fwd wagon
Old 09-20-2010, 02:56 PM   #5 (permalink)
devo's Avatar
View devo's Photo Gallery
I would like to know if the shocks will fit?
devo is offline   Reply With Quote
Old 09-20-2010, 05:50 PM   #6 (permalink)
SuLLiVaN88's Avatar
Gameroom cash: $122837
View SuLLiVaN88's Photo Gallery
i dont think the shocks with interchange without major modifications...
i saw a fx16 at the junkyard here in az the other day i was there i think it had a rear wiper but cant remember forsure
PICKUP PARTS!http://www.toyotanation.com/forum/showthread.php?p=3351792#post3351792
SUPRA PARTS!
http://www.toyotanation.com/forum/sh...d.php?t=360413
SuLLiVaN88 is offline   Reply With Quote
Old 09-21-2010, 01:31 AM   #7 (permalink)
k ill tell her to get new shocks
seems as if the splines are stripped on the rear window wiper stud
Old 09-22-2010, 05:32 PM   #8 (permalink)
That's a new wiper motor
(ELUSIV)
Old 09-22-2010, 06:22 PM   #9 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I think the shocks will fit.
The AE101 springs and struts are a fraction of an inch wider on the bottom than the AE92 units, so if you use the AE101 struts on the AE92, the lower spring seats will have a bit of space around the spring.
You could possibly use the AE101 springs also, but only with the AE101 struts.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 09-22-2010, 06:44 PM   #10 (permalink)
BackYard Engineering
Evo_lucian's Avatar
Gameroom cash: $102535
View Evo_lucian's Photo Gallery
Shocks will fit. Shocks from ae92, ae101 and ae111 are all interchangeable. I got gr2's from a ae91 sedan on my levin and i have a friend with cusco coilovers from a ae111 levin on the ae91 i got the shocks from.
The only thing in life worse than being talked about is not being talked about
My website updated 6/May/11
http://budgetracer.webs.com/
Evo_lucian is offline   Reply With Quote
Old 09-23-2010, 12:39 AM   #11 (permalink)
ok good to hear, thanks guys. fronts and rears work? the fronts i checked are in ok shape but the rears feel like new
also someone took out the factory fan and put an aftermarket fan on but its only around 10 inch
i have access to some aftermarket fans fairly cheap
would a fan that moves 1500-2000cfm be ok?
Old 09-23-2010, 11:06 AM   #12 (permalink)
SuLLiVaN88's Avatar
should work.
I run dual 2500 cfm fans on my truck with my motor swap and even when it was like 115 here in az it didnt over heat and towing a trailer
SUPRA PARTS!
Old 09-25-2010, 04:03 PM   #13 (permalink)
alright
does anyone know if a set of 91 celica gts non power seats will bolt into the 88 rolla? theres a mint blue set in the local junkyard with no cracks or rips?
