Wheel Bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2010, 09:25 PM   #1 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Wheel Bearings
1988 Toyota Corolla 4AF- Automatic/
I am going to replace the cv joints on the car,
How are the wheel bearings in knuckle? Is pressed in?
Is this a sealed bearing?
On some cars I have done there was 4 bolts holding a cover to the knuckle after removing them,bearing was inside. Is there seals? On the wheel bearing?
any diagrams?
Thanks
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 09-23-2010, 09:32 PM   #2 (permalink)
ELUSIV Rolla's Avatar
View ELUSIV Rolla's Photo Gallery
On some cars I did once there was 4 bolts holding a cover to the knuckle after removing them,bearing was inside. Is there seals? On the wheel bearing?
any diagrams?
Thanks
Shoudn't need to touch the bearing at all it if you're just doing the CV joints...
Undo the center nut on the axle/CV, undo 2 nuts and 1 bolt on the bottom of the hub, pop the steering ball joint of the hub, then you should be able to swing the whole assembly out of the way to remove the CV joint.
Then once it's done just slot it back in and do everything up. I have 1 pic of when I changed my hub, see what you can do with it.
Unlike i did, leave the 2 bolts in the bottom of strut in place.
(ELUSIV)
ELUSIV Rolla is offline   Reply With Quote
The Following User Says Thank You to ELUSIV Rolla For This Useful Post:
Mr.Nutcase (09-23-2010)
Old 09-23-2010, 09:45 PM   #3 (permalink)
Mr.Nutcase's Avatar
They are making a humming noise......
I have done CV on other cars...
Do you have any more pics, thanks
Old 09-23-2010, 10:34 PM   #4 (permalink)
No camera sorry, that's an old pic... But the bearings (from what I know) are pressed in, pain in the behind to replace, I use second hand hubs, but that's cause I have heaps lying around. Anyone else know anything?
(ELUSIV)
Old 09-23-2010, 10:35 PM   #5 (permalink)
Actually, I've got one that's split apart, I'll try to figure out how it works, (never actually looked)
(ELUSIV)
Old 09-24-2010, 01:06 PM   #6 (permalink)
SuLLiVaN88's Avatar
Gameroom cash: $122837
View SuLLiVaN88's Photo Gallery
i just did the cv axle in my gts, if i remember right it is pressed in there. im sure that the sedans and coupes have a similiar design. in alot of cases depending on whether or not you have access to a press its easier to buy a new hub assembly. sometimes the hubs arent too expensive i think for yours i saw them on ebay for like 30 dollars
PICKUP PARTS!http://www.toyotanation.com/forum/showthread.php?p=3351792#post3351792
SUPRA PARTS!
http://www.toyotanation.com/forum/sh...d.php?t=360413
SuLLiVaN88 is offline   Reply With Quote
