Got another CEL! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2010, 09:26 PM   #1 (permalink)
devo's Avatar
View devo's Photo Gallery
Got another CEL!
I was driving home and I got a cel got home and checked it is 71 EGR System.
Stated it back up and cel light is off but still in memory when I use the port to check it. Can I clear it and go get a smog? or can I fix it in enough time I need to do it saturday thats the last day of my extention. Oh and how can I fix it???
devo is offline   Reply With Quote
Old 09-25-2010, 06:16 AM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Here's a link on some general info on code 71. Sounds like valve could be carboned up or a vac line broken on egr valve or plumbing attached to it. Also to test egr valve disconnect vac hose going to it and apply a direct vac line from another fitting. When you connect vac the car should run rough or stall. That indicates valve is functioning properly.
http://wiki.answers.com/Q/If_a_1995_...r_this_problem
90 GP is offline   Reply With Quote
Old 09-25-2010, 10:55 AM   #3 (permalink)
devo's Avatar
Ok cool where is the EGR located? and damn I looked up one at auto zone and its $$$$!
Old 09-25-2010, 01:32 PM   #4 (permalink)
Not sure which engine you have but this shows where located on 4AF(4AFE should be similar) and 4AGE. Try cleaning the old one and checking all vac lines before laying down cash on a replacement.
http://www.autozone.com/autozone/rep...00c1528006f1ff
The Following User Says Thank You to 90 GP For This Useful Post:
devo (09-26-2010)
Old 09-25-2010, 02:00 PM   #5 (permalink)
devo's Avatar
I have a 4AF and thanks man!
Old 09-25-2010, 08:46 PM   #6 (permalink)
devo's Avatar
Ok
I tested my EGR valve with my mityvac and that seems ok applied vacuum and it killed the engine went ahead and took it off and cleaned it with some carb cleaner.
I checked the modulator valve from the bottom port and it has a slow vacuum leak so this may be the culprit.
I am going to the salvage yard tomorrow to get one none of the parts stores near me have one in stock, I just read that the same valve is in the celica and the corolla from 89 to 95.
Old 09-26-2010, 03:39 AM   #7 (permalink)
Check all those vac lines that go to and between the pieces for EGR and modulator. Also check connections at the TVSV (thermal vac switch threaded in engine) as that is the main feed for the vac to the system. Also the TVSV could be faulty and not opening allowing EGR to get vacuum.
Old 09-26-2010, 11:17 AM   #8 (permalink)
devo's Avatar
Ok will do I am getting ready to hit the junk yard.
