oil light wont go off!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2010, 07:21 PM   #1 (permalink)
View 4dRcOrOlLA's Photo Gallery
ok my oil light came on when my car was jus siting in my garage for like 4 days so i check the oil n it was low then i tried to reset the light to turn it off by takin the neg cable out n it still there! i even pulled the positive out too n its still there. any advice would b appreciated, jus hope it nothing costy to fix thanks
4dRcOrOlLA is offline   Reply With Quote
Old 10-05-2010, 11:29 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
Could be the oil pressure sensor itself. Or the oil pump, clogged oil filter, or in need of new oil.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 10-06-2010, 01:49 AM   #3 (permalink)
View nizzehult's Photo Gallery
Oil pressure sensors seems to fail often. Happend to me a couple of times at a number of japanees cars, different makers.
Less then 10 bucks for a new one. Easy to swap.
If the oli pressure really is bad you should here a metallic sound from the engine while running.
nizzehult is offline   Reply With Quote
Old 10-06-2010, 06:24 AM   #4 (permalink)
So where is this sensor located at ? And I can't hear nothin because my. Steering is squealin right now lolz thanks guys
Old 10-06-2010, 08:12 AM   #5 (permalink)
I think it's located right above the oil filter. Check this pic:
http://www.toyodiy.com/parts/p_E_198....html?hl=83530
Old 10-06-2010, 01:56 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Thats when you've toasted your engine.
If you're sure its not the oilpump and that you have correct oil pressure, then change the sensor, its behind the alternator. I'd hook up an oil pressure gauge to be sure.
Old 10-06-2010, 11:48 PM   #7 (permalink)
ELUSIV Rolla's Avatar
View ELUSIV Rolla's Photo Gallery
I've recently hit the same problem, not staying on but taking ages to turn off, oil press gauge says everything is normal though. Weird.
My solution, unplug the sensor lol.
(ELUSIV)
ELUSIV Rolla is offline   Reply With Quote
Old 10-07-2010, 12:03 PM   #8 (permalink)
blb
View blb's Photo Gallery
If you want to diagnose the problem rather than throwing parts at it, here's how the circuit should work.
With the connector pulled off of the oil pressure sender and with the key on the "on" position, if you ground the contact in the connector, the oil light should be on.
Again with the connector off of the oil pressure sender, if you use an ohm meter and check for continuity, with the engine off, there shoud be continuity from the post on the sending unit (where the connector attaches) to ground. With the engine running, there should not be continuity from the from the post on the sending unit (where the connector attaches) to ground.
Most times, they fail so that the light is on when it shouldn't be however, last weekend I changed one that failed so that the light never came on when it should have.
blb is offline   Reply With Quote
