I might be wrong, but I don't think you can just take the drive shaft out. I think you will probably need to swap the gearbox/transmission to a FWD unit.
That will probably save you a little weight, but I doubt enough to make a noticeable fuel saving.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
What gearbox or transmission do you have?
3spd, 4spd, 5spd?
3500 RPM at 65 mph sounds like the differential ratio in that gearbox is the same as the GT-S. That is close to the RPM/mph ratio I had before I swapped in the 7A-FE engine with it's gearbox. Actually I had somewhere near 3700 at about 70 mph, I never checked it at 65.
Now it has dropped to 3150 RPM at about 70 mph, and my milage has gone up by about 2 mpg.
If that is the case, then swapping in a 5 spd gearbox from a regular FWD sedan should give you about the same change I got.
Just guessing.
Lol, flashmn..."Here we go again." sorta. If you swap out the gearbox, you need to change the CV joints too, the splines are different. Oh and to lower the rpm at the 5th gear might need to think about finding a different gearbox with lower gear ratio like Donald talked about. Then hope it all fits. If you want a FWD, just sell the alltrac and be able to afford two regular FWD corollas...Im sure theres plenty of people that wouldnt mind having an alltrac that has awd still in it. Just my two cents.
This. There aren't that many of these All-Trac beauties around as it is, leave it alone! I know someone in the Tampa Bay area who would love to buy an All-Trac wagon, especially since it's a 5 speed manual.
On a side note, if I'm allowed to mention this... it's too bad the All-Trac forum sort of vanished. It's been down a few days now.
