has anyone ever experianced this problem
so my clutch was acting kinda annoying. everytime i step on the pedal i would notice and feel a thump on on the pedal. i finally looked at it and it turns out that my slave cylinder was not fully pressed on my shifter fork (so the thump i felt was the slave cylinder lineing up with the fork when it pushed far enough). so i bleed the slave cylinder and it stopped doing it. the next day i drove the car again, same thing happend. i checked the fork and slave cylinder play again, same thing. so i thought, maybe it was a bad slave cylinder. this happend after i was able to press the fork against the slave cylinder, it actually ended up depressing the slave cylinder instead.
so i replaced the slave with one of the spare ones i have. bleed it, then i tried pressing the fork against the slave cylinder again. same thing it ended up pushing the whole slave all the way back. as i did this i could hear fluid going back into the clutch fluid reservoir.
in conclusion to this i'm pretty sure its the clutch master cylinder. its just that it never leaked. so as the title said has anyone of you guys had this happen?
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
