16" rims on an AE92? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2010, 10:49 PM   #1 (permalink)
View Blade's Photo Gallery
AE92 16" rims on an AE92?
Hello,
I am thinking on upping my rim size on my GTS. I found some nice 16" Konig rims with 205/45/16 tires. I was wondering if anyone has rims like this on their car and if it made a positive or negative difference? I can imagine that the handling will be better due to the low profile tires, but I am worried about the acceleration. Does anyone have advice for me before I buy these tires?
Thanks!
Blade is offline   Reply With Quote
Old 10-18-2010, 01:33 AM   #2 (permalink)
View NZAE92's Photo Gallery
hey
your acceleration won't be affected that much if you have lightweight rims you probably will get better response from lightweights. obviously with heavier rims they will be harder for the engine to spin therefore decreasing your acceleration.
NZAE92 is offline   Reply With Quote
Old 10-18-2010, 02:59 AM   #3 (permalink)
Thanks for the response. I didn't think it would be too much, but I am just wondering if its noticeable. Have you put 16" rims on an AE92 before? I am not sure if they are lightweight, but they are aluminum and appear to be rather slim and small. I have not seen them in person yet to know if they are heavier then the stock ones, but I don't see them as being heavier.
Old 10-18-2010, 05:39 AM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
I had 17's before. It lasted me only 10 miles before I decided to take them back off. Acceleration lagged a lot. All I heard was the engine revving high going nowhere. 15x7 wheels with a 38+ offset is the best bet paired with 205/50/15 or 195/55/15 tires. I believe those are the best tires for that size.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 10-18-2010, 05:27 PM   #5 (permalink)
SuLLiVaN88's Avatar
Gameroom cash: $122837
View SuLLiVaN88's Photo Gallery
16s will fit depending on your offset for each size of tires. i havent noticed any performance loss with my 16's on. but they are light
PICKUP PARTS!http://www.toyotanation.com/forum/showthread.php?p=3351792#post3351792
SUPRA PARTS!
http://www.toyotanation.com/forum/sh...d.php?t=360413
SuLLiVaN88 is offline   Reply With Quote
Old 10-19-2010, 01:48 AM   #6 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
I have 195/50/15 rims on mine, with +35 offset. Fits perfect, no rubbing, and is the correct tire size for a 15.
I'm curious as well about 16s and how well they fit. As far as I know it shouldn't be any problem, but most of the Konigs are +40 offset which might be too much for your rears to clear unless you use skinnier tires, or spacers. And I believe you would want 205/40/16 for being closest to stock height to keep speedometer correct. Also 195/45/16 should work as well for better clearance.
Createdtoburn is offline   Reply With Quote
Old 10-19-2010, 10:55 AM   #7 (permalink)
SuLLiVaN88's Avatar
my 16's with 195/45r16 when i put em up next to my stockers were about the same size. but my 14's had 205/60r14's
SUPRA PARTS!
