Issue 1: Common with my taillights. Because of age and heat build-up from the wires, they usually melt wire insulations. When this happens, now you have short circuits that may not blow the fuse but cause your current problem. You can either do a re-wiring yourself (only at the bulb panel of both taillights) or get one from the junkyard that is still in tact.
Hell, my third brake light, the damn light bulb melted the red lens.
Issue 2: It can be a retarded timing or excessive fuel. I would try to do a re-timing first since it's the cheapest (free if you do it yourself).
Issue 3: If it squeals, check the belt. Nice method I use, on any belt, the part of the belt that is longest between two pulleys should not deflect more than half an inch. Just take a finger (while the car is off), press down on the center of the belt in the spot said. If you're able to push it down, with not much power, more than a half-inch, it's loose.
Part: Best bet is the junkyards. You can try RockAuto.com, sometimes eBay. They may have it. Sorry about the break-in, my corolla got broken into twice. Next time, I'll make sure to rig my car with explosives for an alarm. I hate those bastards.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
