Help deciding on New Clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2010, 04:54 PM   #1 (permalink)
View JKromberg's Photo Gallery
hey there, i am need on a new clutch. what kits would you suggest me to get. i dont race it often, it is mainly a daily driver for me.
1992 corolla dx sedan 4afe
edit: i am thinking about the ACT Clutch Kit Heavy Duty/Race Sprung - Ceramic disc, Sprung hub - 4 pad. does anyone have this?
JKromberg is offline   Reply With Quote
Old 11-10-2010, 10:10 AM   #2 (permalink)
bump.
No one knows anything about a decent clutch? that surprises me.
Old 11-10-2010, 10:33 AM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
don't get a 4 puck clutch
I have a ACT street disc on my 270whp rx-7 and I've never had it slip.
I would just get a OEM replacement (look on rockauto.com) and no waste your money on something you don't need...
or just get an ACT HD pressure plate and an ACT modified street disc. (part #: TL3-HDMM)
I love the ACT on my rx-7. I have an OEM clutch on my 20V SR5 that I auto-x regularly.
'81 BMW R65
Old 11-10-2010, 11:08 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Unless your car is really modified, then you dont need anything else than a stock clutch.
Old 11-10-2010, 12:00 PM   #5 (permalink)
any preferences on stock clutches then?
Old 11-10-2010, 12:17 PM   #6 (permalink)
rdyzz's Avatar
Gameroom cash: $137500
View rdyzz's Photo Gallery
oem toyota or exedy. unless you have plans for a turbo i would not go higher than a stock replacement.
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
Old 11-11-2010, 08:54 PM   #7 (permalink)
View kcwa's Photo Gallery
..I got a decent clutch and pressure plate from rockauto... still waiting until I have to install it on my daily driver.
1990 Corolla SR5 Coupe 4AFE 5-speed
"Gentlemen, you can't fight in here! This is the War Room!"
~ Dr. Strangelove, 1964
kcwa is offline   Reply With Quote
Old 11-12-2010, 12:18 AM   #8 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
+1 on stock replacement clutch. It wont slip unless the engine is heavy modified like others have stated, and your left leg will thank you when getting stuck in traffic.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 11-13-2010, 07:51 AM   #9 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
I'd use one of the following...
$74.53 - F1 Racing Stage 1 Full Organic Clutch Kit - http://www.ultrarev.com/f1-56005r0.html
$91.64 - Exedy OEM-spec Replacement Clutch Kit - http://www.ultrarev.com/16070.html
There are probably cheaper prices out there. I just used UltraRev because that's where I bought my OEM-spec replacement for my MR2 Turbo. Surprisingly, I've never heard anything bad about F1 clutches despite how cheap they are.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 11-14-2010, 04:21 PM   #10 (permalink)
rdyzz's Avatar
i'm actually using an f1 setup in my corolla. the flywheel has quite a bit of holes drilled, but its made of chromoly and should be even more durable then an aluminum one. it feels like a stock clutch actually. this might be due to their painted pressure plate. which im sure is either stock or a stock aisin plate with uprated springs.
Old 11-15-2010, 07:50 PM   #11 (permalink)
how does the clutch feel?
and should i get a new flywheel while im at it?
Old 11-15-2010, 09:42 PM   #12 (permalink)
rdyzz's Avatar
honestly if i could redo it i would use and oem replacement exedy and pair that upwith the f1 10lb flywheel. this should help with making your car accelerate a little better. as far as the f1 clutch it engages at the point where your feet lifts almost all the way off the pedal. it doesnt feel as good as the stock clutch nor the act ones i've had in the past, but it was cheap and i wanted to test it out.
