Exhaust Woes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2010, 03:14 PM   #1 (permalink)
View numero9's Photo Gallery
Exhaust Woes
What's this part called... it had a houndstooth kinda pattern cover over it, but mine frayed off. Between the cat converter and where it goes underneath the hood. I've got a crack in mine and I noticed that my car is having a harder time starting and a very prevalent rattling noise when accelerating from a stop. Especially when just starting the car. Seems to disappear when driving, but it's getting worse.
How can I patch it up really inexpensively? I only need my Corolla for 2 more months and now this came up.
numero9 is offline   Reply With Quote
Old 11-11-2010, 03:45 PM   #2 (permalink)
View NZAE92's Photo Gallery
AE92
hey
it would be a lot easier if you could take a photo of the part
you are having a problem with and we could tell you easily. but it sounds like it might be your exhaust manifold that has a crack in it, im not sure can anybody second that?
Greg
NZAE92 is offline   Reply With Quote
The Following User Says Thank You to NZAE92 For This Useful Post:
numero9 (11-12-2010)
Old 11-11-2010, 03:59 PM   #3 (permalink)
Here, the lower part on this: http://www.corsportusa.com/store/cat...ustmanifol.jpg
Is that all considered the manifold? I only thought it was the top part for some reason.
Old 11-11-2010, 04:08 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
it's called a flex pipe.
you can either go to an exhaust shop and get it replaced (fairly cheap) or just deal with the noise, it won't hurt the car at all.
'81 BMW R65
The Following User Says Thank You to eage8 For This Useful Post:
Old 11-11-2010, 04:29 PM   #5 (permalink)
Well the problem is that I notice its been harder and harder to start. It seems to be correlating with the pipe because I noticed it wasn't that bad and making some noise but the car would still start (the pipe was rusty, but no visible cracks or holes), now the rattling is much worse and the car barely "makes it" starting up (now I can see a decent crack in that pipe). I have to give it some gas before putting it into gear. I notice the car pulsing on idle worse, too.
I just had the timing belt, water pump, fuel filter, oil change, wireset and distributor cap, new transmission fluid, and belts changed/put in. It's not an electrical problem because it does turn over and all electrical components work, battery/alternator are fine. Not throwing any codes either, I had a MAP sensor issue a long time ago and swapped it out with success. So I can't think of what else it could be and since it's happening as this pipe is getting worse, it seems likely.
Old 11-11-2010, 04:45 PM   #6 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
That flex pipe hole shouldn't be causing any hard start issues. How did it start before you had the timing belt etc. replaced? If the hard starting began after that take it back to them. They might have installed the timing belt off a notch and it is out of time or an electrical connector or vac hose in the area they were doing the work was never reconnected.
90 GP is offline   Reply With Quote
The Following User Says Thank You to 90 GP For This Useful Post:
Old 11-11-2010, 06:03 PM   #7 (permalink)
It was pretty much the same. Any other ideas? I just notice that it got worse today and that's when the sound from the pipe got a lot worse too. It feels like there's not enough fuel getting to the car for some reason. It's fine after about 5 minutes driving it around and there's no rattling noise after that either. I notice some starting problems after I drive around and then starting it up after 20 minutes or so. If it's like 5 minutes between starts, not bad. It's just starting it up after all night then medium length trips like that.
Old 11-12-2010, 05:05 AM   #8 (permalink)
There is a cold start injector which richens the mixture to aid cold start. Can see it on fuel rail as a separate line going to intake manifold. Possible fuel pressure regulator failure. It's located at end of fuel rail with a vac line. Maybe the fuel pump is getting weak. Before starting did you ever try turning key to on position for a minute before cranking to allow fuel line to pressurize?
Old 11-12-2010, 07:48 AM   #9 (permalink)
Hmm, I'll check it out today and report back.
Old 11-12-2010, 09:27 AM   #10 (permalink)
Rotary guy...
eage8's Avatar
are you sure it's not just because it's getting colder out? cars always struggle to start when it's colder...
'81 BMW R65
Old 11-12-2010, 09:42 AM   #11 (permalink)
No, it was doing this throughout the summer too. Just less frequent. It hasn't been that cold here lately either (lower 70s).
Old 11-12-2010, 10:59 AM   #12 (permalink)
Tried again with leaving it in the "on" position before starting for a minute. It stalled out on the first start then started up on the 2nd -- that's about where it was a couple weeks ago.
I checked for any diagnostic codes again and I got nothing. The manifold was cleaned out about 4 months or so ago and it didn't change anything, too.
Old 11-12-2010, 12:21 PM   #13 (permalink)
Here's a link dealing with cleaning the cold start injector if you want to give it a try.
cold start injector
Old 11-12-2010, 02:19 PM   #14 (permalink)
So I thought I knew where this thing was, it's smack dab on the intake manifold with a black/green plug out of it, right? I tried to take it off and it started spraying gas, anyway to avoid that happening again?
Old 11-12-2010, 03:15 PM   #15 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Pulling your gas tank cap can help relieve some of the pressure, but won't stop it completely.
Wrap an old rag around it to catch the fuel, but you will still get some on the ground.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
The Following User Says Thank You to Donald For This Useful Post:
