AE92 Project log- 89 sr5 4af engine project :D - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2010, 01:26 AM   #1 (permalink)
View ae924af's Photo Gallery
Well its that time for me. I have finally figured out where im going to go with my project. I have an 89 corolla sr5 that I am currently working with. It has a 4af engine in it but Im going to work with what I got Anyway Currently I have ordered EBC Vented Rotors, EBC green stuff brake pads, KYB GR2 shocks with Ebachi Lowering springs. I also have a Pacesetter header coming my way within a week or so. From there it will be complete exhaust with a Injen muffler. Once I get these parts in place Im planning on buying a Weber 32/36 and a K&N Plenum so I could run a cold air intake without modifying my hood. Of couse I am going to get a complete gasket set as well. Then maybe get a Whiteline sway bar. Between this time I hope to have time to work on the body... mostly get the oxidized paint taken car of. I fixed the leak in my trunk this weekend and resealed everything in the back. My question at this point is are there anything else that I could do that would be worth the Money? Im going to try and up date this as much as possible with the project.
ae924af is offline   Reply With Quote
Old 11-20-2010, 02:19 AM   #2 (permalink)
View NZAE92's Photo Gallery
not trying to be negative or anything but a black or silver top 20 valve would be worth the money but, like you i also am not going that route.
I'm also doing a project with the 4af,
I'm bidding on a 32/36 dgav weber from a ford pinto 2L engine which should bolt up quite nicely and also getting a cam grind which you should also keep in mind if you are wanting power.
if you want info on what i have done to my 4AF just send me a pm i'm more than happy to tell you
Greg
NZAE92 is offline   Reply With Quote
Old 11-20-2010, 10:27 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
EFI parts from a junked 4A-FE, programmable efi and a turbocharger, nuff said.
Old 11-20-2010, 01:32 PM   #4 (permalink)
AE92
Wish there was a 'Like' button.
Old 11-20-2010, 06:05 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Started off as a 4A-F
Old 11-20-2010, 06:09 PM   #6 (permalink)
What kind of exhaust is that? So to do that I would need a Intake manifold for an 4afe and then the ecu plus the other fuel injected components and they will bolt right up?
Old 11-20-2010, 06:34 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Self made exhaust. well I'm running KMS (van kronenburg) injector controller with bosch 390cc injectors, Map sensor from VW/Audi, Walbro 255 fuel pump, Volvo 240/740/V70 fuel filter, Amworks fuel pressure reg (1:1 rate).
Will they bolt up, well the intake manifold will, you'll have to have injector bungs machined into the head (theres spaces in the head for it, on the 4A-F they havent been machined).
All in all if you want to modify a 4A-F, you're going to run out of "bolt-on" parts quite fast. You really gotta think out of the box.
Old 11-20-2010, 09:09 PM   #8 (permalink)
DO you have anymore images of what you did with the 4af engine?
Old 11-21-2010, 05:38 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Whatcha mean, pictures of what?
Old 11-21-2010, 02:25 PM   #10 (permalink)
AE92
I think he means builld pictures? or more pictures of your engine
Old 11-21-2010, 02:45 PM   #11 (permalink)
Yea thats what I meant... thanks
Old 11-21-2010, 03:06 PM   #12 (permalink)
Resident asshole
Flashmn's Avatar
Nope, I really didnt take any, I just did the stuff and installed them and took a pic of it installed. My sneek preview of things to come thread has some pics.
Tags
4af, ae92 rebuild, project
