E brake after conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2010, 09:34 AM   #1 (permalink)
View Gsr Mann's Photo Gallery
I did a drum to disc conversion on my 1990 DX with parts from an AE92, the e brake ratchets to 3 but does not hold, already did adjustment to tighten e brake at console. Need Help
Gsr Mann is offline   Reply With Quote
Old 11-29-2010, 10:45 AM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Does the ebrake lever on the calipers function? Maybe the mechanism inside the caliper is seized?
SuperRA is offline   Reply With Quote
Old 11-29-2010, 11:52 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Possible, but most likely its the bearing where the HB-actuator rotates the pin to engage the HB thats worn out, causing the HB-actuator to tilt while engaging, so the handbrake lever clicks, but the handbrake wont hold
Old 11-29-2010, 03:46 PM   #4 (permalink)
where is the actuator located, if it is part of the caliper the caliper was serviced my mechanic everything is ok according to him.
Old 11-29-2010, 04:43 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
its the hook part on the caliper which twists to push the piston outwards. Hard to check it without it being on the car.
