a little history first, engine had 230,000 miles on it, it ran rough, misfire under load. bought another 4afe from japan with low miles, put it in the car. replaced cap and rotor, fuel filter. car ran great! burned half tank of gas, on the way to work one morning it started to missfire when changing gears. didnt think a thing about it till i got into it after work and NO SPARK. havent seen spark since
ok im at wits end. and my wife is ready to throw in the towel. bought a rebuilt distributor, returned it for another one. bought a said working computer, with same #'s on it, found #1 tdc aligned crank. made sure rotor pointing at #1.
Still no spark, I have a dwell meter, before i bought the ECM i tested the IGT wire and got nothing, thats why i bought the ECM. Checked fuse block in engine bay and on driver side and driver kick panel. ohmed out every fuse, the coil is getting 12 v to the +ve and -ve side of coil with key switch on.
Please help
ill do anything again. sunk over $1300 into this thing now, this should be a nice car. I even talked to it, sang to it and preyed over it. still no spark.
