need help to install clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2010, 08:42 PM   #1 (permalink)
View keeby626's Photo Gallery
Hi guys, im new to this forum and i just picked up a 1989 corolla gts 5speed. its a sweet ride but the clutch is slipping. i want to change it myself. does anyone have step by step info or pictures and any links that can help me change out the clutch easier and save me some time. thanks for all the help
keeby626 is offline   Reply With Quote
Old 12-10-2010, 02:23 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Do you have some experience changing out a clutch?
I might have miss some steps. This is all from when I did my auto-to-5spd swap. Wrote this in 5 minutes. If wanted, I can possibly scan the pages out from the FSM and send it to you via email.
Basically:
You may need an engine hoist and a rolling hydraulic jack or two rolling hydraulic jacks, whichever you prefer. One for engine, one for trans.
Raise front of car about 2 - 3 ft, have on jack stands.
Disconnect battery, remove starter, unhook all transmission wirings, clutch lines, cables. Can also remove top transmission-to-engine bolts.
Remove wheel assemblies, unbolt lower ball joints from hub assemblies, remove both CV axles from hub (can be entirely removed if so).
Remove lower subframe (center bar and the crossbar that have the control arms). The engine/ trans assembly is held on by four mounts, two will be on the bottom bolting to the subframe so the last two will hold the assembly up, no problem.
Remove driver side hub, if necessary for access.
Utilize a rolling hydraulic jack for the engine. Use a piece of wood to put in between the jack and the bottom of the oil pan, prevents the pan from getting damage. Utilize another jack for the transmisson.
Loosen the rest of trans-to-eng bolts. Then unbolt the top driver side mount, making sure jack is in contact with the trans so it doesn't drop and ease of mount unbolting.
Slowy drop the jacks down, the engine/ trans assembly should angle down towards the driver. Lower down until it is enough clearance for trans to clear chassis.
Remove the rest of the bolts, gently wiggle the trans away from the motor.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
The Following User Says Thank You to SCT For This Useful Post:
keeby626 (12-10-2010)
Old 12-10-2010, 02:34 AM   #3 (permalink)
wow thanks sct. your write up is awesome. but just to be on the safe side, can you email me the pages. my email is keeby82sim@yahoo.com. thanks alot!! i think i should have no problem doing my clutch with your write up. o i almost forgot, can you tell me what types of fluids you used and how much i need to get and if there is any torque specs i need to know. thanks again.
Old 12-10-2010, 03:07 AM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Didn't catch your edits in your post before I sent the email. I'll send you a second email that'll be the torque specs from the FSM. Some specs will not apply, just to let you know, unless you were taking the trans apart or something.
As for the fluid if you drain out the trans, use 75W90 Gear Oil or 80W90 Gear Oil. Takes about 2.7 quarts. For the clutch fluid, DOT3 Brake fluid.
Old 12-10-2010, 03:32 PM   #5 (permalink)
Sweet!! thanks again SCT!!
Old 12-10-2010, 03:42 PM   #6 (permalink)
o hey SCT, one more thing. what size nut is on the axles?
Old 12-10-2010, 10:19 PM   #7 (permalink)
plyr503's Avatar
View plyr503's Photo Gallery
32mm i believe
plyr503 is offline   Reply With Quote
Old 12-11-2010, 05:21 AM   #8 (permalink)
SCT
iAzn
SCT's Avatar
Originally Posted by plyr503 View Post
32mm i believe
Old 12-11-2010, 08:04 PM   #9 (permalink)
thanks guys. im also changing out the flywheel too. do you know the torque spec for the flywheel?
Old 12-12-2010, 10:42 AM   #10 (permalink)
plyr503's Avatar
54ft lbs for an 88, there can't be a whole lot of difference for your 89 I wouldn't think.
Old 12-12-2010, 01:26 PM   #11 (permalink)
ok sounds good. thanks again
Old 12-14-2010, 09:07 PM   #12 (permalink)
thanks guys for all your help. i finished install the clutch and flywheel. took me about 6 1/2 hours to finish everything. everything went as you posted. thanks again
