Sway bar mounts/brackets - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2010, 09:51 PM   #1 (permalink)
DX? Doesn't seem deluxe!
Brown_Muscle's Avatar
View Brown_Muscle's Photo Gallery
Where can you buy the sway bar mounting brackets for the front and rear bars? I can't seem to find them anywhere... thanks
-Phil
-Phil
1992 Corolla DX 5-speed, GTS front and rear sway bars, 15" Motegi Racing rims with 205/50R15's, Aftermarket strut bar, JVC Head Unit, Pioneer Speakers, 10" Polk Sub+Amp, Front Lip Mod.
1982 Ford LTD-S Police Car 351 Windsor
Brown_Muscle is offline   Reply With Quote
Old 12-10-2010, 09:57 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
Dealer?
Old 12-10-2010, 10:15 PM   #3 (permalink)
plyr503's Avatar
View plyr503's Photo Gallery
or rockauto they've got them on there
plyr503 is offline   Reply With Quote
Old 12-11-2010, 10:03 AM   #4 (permalink)
plyr503's Avatar
oops not on rockauto sorry.....wrecking yards the place to go....thats where I got the whole sh*t and shabang for my 92 dx, front and rear. Cost me all of 21$
Old 12-11-2010, 04:03 PM   #5 (permalink)
sounds like i'll have to try the dealer...thats where i got the sway bars from.. no yards around here have any GTS's unfortunatley
-Phil
Old 12-12-2010, 12:37 AM   #6 (permalink)
plyr503's Avatar
you'll need the control arms as well for the front if you got a gts front sway bar....I used an all-trac sway bar on mine, the sway bar link bolts into the dx control arm. From what I've seen the gts' have a small bracket welded on to the control arm where the sway bar links attach.....
there is a pic or two on the link that show the bracket needed for a gts sway bar
http://forums.club4ag.com/zerothread?id=39279
Old 12-12-2010, 01:13 AM   #7 (permalink)
thanks man, i'm aware, i intended to fab and weld the tab onto the control arms.
-Phil
Old 12-12-2010, 10:36 AM   #8 (permalink)
plyr503's Avatar
sweet...I didn't do my homework when I got my first set of sway bars...
Old 12-14-2010, 06:10 PM   #9 (permalink)
Perhaps you can answer this question for me...since many answers i've found are conflicting...even if i can't find stock rear brackets/bushings i should be able to use aftermarket ones...(I have to drill holes into the body as mine has no pre-drilled holes )
With the front though, the sway bar needs specially designed brackets to bolt to the sub-frame/body? or does it simply bolt under the sub frame with a bushing? It looks like it is a looped piece of metal that wraps around the bushing and is bolted to the body along with the sub frame, correct?
Also does anyone know the stock diameters of the sway bars?
-Phil
Old 12-15-2010, 01:44 AM   #10 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
The front OEM GTS sway bar needs the rear control arm brackets from a GTS because it (the sway bar) bolts to that rear control arm bracket and then that bracket then bolts to the body/subframe.
SuperRA is offline   Reply With Quote
Old 12-18-2010, 07:26 PM   #11 (permalink)
Got um from toyota, thanks guys I will be doing a full detailed write up on how to install the bars on a sedan when finished including build pictures.
-Phil
Old 12-18-2010, 11:33 PM   #12 (permalink)
plyr503's Avatar
no pre-drilled holes ? that sucks....I was so lucky that mine not only had the holes where the mounts bolt in,they still had the plugs they installed at the factory so dirt wouldn't get in there.....
Old 12-19-2010, 10:30 AM   #13 (permalink)
Lucky...It is possible the holes are there...but the underside of the car was coated for rust when new...however there are no dimples or protrusions indicating there are any holes or plugs there...i may find out when i start to drill though.
I hope i will have a drill bit long enough to go all the way through, that's my only worry...not much of one though because i can just buy a longer one XD
-Phil
Old 12-19-2010, 10:42 AM   #14 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
a lot of times they're there and just covered with black stickers...
why are you going with stock sway bars? it would be nicer to get a set of whitelines :P
'81 BMW R65
